Question about Ruud UBHC Air Conditioner
Rudd furnace I have a RUDD furnace model UGPJ-07-NAMGR. It had stopped working, so I replaced the thermostat but it is not the thermostat. When I hold the furnace reset button, the furnace will fire according to the setting on thermostat(heat or fan). As soon as I let go of the reset button, the heater stops working. It does not matter what I do to the thernostat, the heater will not fire. I crossed the red and white wire but nothing happens. The heater is supposed to fire when I cross wire, right? Thank You, David
  • 1 more comment
  • dchinoraks Jan 03, 2009
    Yes! when I connect them (red and white wire) together and let them connect for a minute, the furnace does not start.
    Usually, when I turn thermostat up for heat, I hear "Click" and heater starts.
    Thank you!
  • Danny Clark
    Danny Clark May 11, 2010
    When you cross white, you are basically just bypassing the T-stat.
    Please describe for me exactly what you are reffering to as the "furnace reset button" and where is it located?
  • Ken Bledsoe May 11, 2010
    When you cross is that meaning jump between them? R and W or red and white.
  • 659 Answers
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Posted on Jan 05, 2009
Single mom, trying to get heat at midnight...I found the limit switch button between the 2 wires, it wiggles, but I can't get it to go in or out...
Posted on Dec 04, 2009
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
RUDD Furnace is not responding to thermostat, blower is stuck on. What might be causing this?
fan control stuck on turn power off fan will stop then turn back on , you could need new fan control or it is dirty at the back of it .
Dec 08, 2010 | Heating & Cooling
I have a Rudd AC unit Model UEAB-1410BF5. The AC works, the fan works, but the heat will not come on. It was working, then one day stopped. When you try and get it to come on nothing happens. Thought it...
Remove red and white wire from t-stat and connect if it starts then it is t-stat.
if not jump out at furnace where wires connect to it.
could be an inducer motor problem?
Feb 04, 2010 | Heating & Cooling
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Rudd model ubhk-24jinfg
Check your filters inside the furnace, replace if needed. Then check to ensure that the fan is running inside the furnace. If these two things dont fix the problems, I would imagine you have low refrigerant issues. In that case you should call a service company.
Hope this helps ya please rate me.
Jun 20, 2008 | Ruud Central System Air Conditioner
Ruud UBHC Air Conditioner Logo
1,108 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
