Fujitsu siemens amilo m3438g
I am still not confident in fitting a second hard drive to this computer. I have got the drive plus an installation kit with lots of gits. I am not sure what goes where.
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
I got Fujitsu Siemens AMILO pro V1000 laptop , the problem is there is wireless device inside the laptop but i can't see it in my computer .....> hard drive ...> device manager .... > network...
A wireless hard drive? Wouha, you're lucky...
1. It's possible that the wireless adapter is disabled in the bios -> enable it.
2. Maybe it's only disabled in the device manager -> enable it.
3. It can be that the drivers for the adapter aren't installed -> install them.
Hope helps.
May 30, 2017 | Fujitsu Siemens AMILO Pro V1000 Notebook
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
How do i turn my wirless connection on my fijitsu siemens amilo pro
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
Je veux telecharger gratuitement le pilote de carte son de siemens amilo L7300
Bonjour ,
Afin que vous voulez telecharger driver carte son gratuit pour Siemens AMILO L7300 voici le lien http://ts.fujitsu.com/support/downloads.html
ERNZ
Jan 31, 2010 | Fujitsu Siemens Computers & Internet
Fujitsu Siemens AMILO D1845 keeps freezing
have you tried a fresh install of xp I do not understand?
Oct 24, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
HI! Yes you can upgrade your Hard drive from a 30GB (std size) to as much as 120GB. The only thing yu need to be sure of is that you need to buy a IDE 2.5" HDD which is a little bit hard to find but is still available. Try to google some suppliers online.
Hope this Helps.
May 20, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo d7830 hard drive
Yes, you can up to 120 GB IDE 2.5" HDD. You can buy it from any PC store near you ar order online.
Hope this Helps.
May 08, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Not blank disks supported by ricoh 8165 dvd r/rw
most likely your optical drive is out dated or it is internally damaged you may need to upgrade or up date a drive that will fit in your computer.
Mar 15, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Dec 15, 2007 | Fujitsu AMILO Pro V1000 Notebook
Computers & Internet Logo
378 people viewed this question
David Payne
David Payne
