Question about Panasonic PV-C1341 13 in. TV/VCR Combo
TV wont start.
Hi, I have a PV-C1341 which wont start on power on. Only the Prog Timer LED keeps flashing on Green. When I press the Power button I can just hear a click sound, thats all, and there is nothing on the screen. Also, I can insert a video tape and eject it, but it wont play, rewind or forward. Please help. thanks in advance! Harry.
  • 277 Answers
SOURCE: Panasonic PV-M1359W 13 in. Combo
hi reset the combo: http://www.fixya.com/user-guide/p231976,m7872,gm36/Panasonic-PV-M1359W363-in-Combo.aspx good luck
Posted on Apr 09, 2006
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
SOURCE: No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Posted on Jun 06, 2007
mybradley7
  • 242 Answers
SOURCE: Panasonic VCR ejects wont play tape
check the tip in my profile
Posted on Jul 31, 2010
SOURCE: Can't tell if tape is recorded.
Well thanks that you found out. i was going to tell you to do exactly what you did because the timecode rreads where it is tapes and does not where it's not.
Posted on Nov 25, 2011
Silvanya LC321SS9 B standby led... wont turn on
Could be an open internal fuse or power supply failure
Nov 18, 2016 | Sylvania Televison & Video
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
Panasonic PV-M2738 flashing light
A BAD PCB (power control board) maybe cheaper to buy new combo
Jan 17, 2008 | Televison & Video
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wont turn on
Hi Bismi, my PV-DM2792 behaves for last four days in the same way - double clicks when power button is depressed and the light PROG is flashing every second continously. I have called to the Panasonic customer service and they could not propose a solution to this problem other than contact an authorized dealer in my area. SirJ
Jul 12, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Panasonic PV-C1341 13 in. TV/VCR Combo Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
