Question about Sewing Machines
Power Problems The power cord in fine. It is from another identical machine which has no problem. The foot pedal is fine for the same reason. I have cleaned around the motor which was quit dusty but still have the problem that the power is erratic. Sometimes when I jiggle the cord it will work but mostly not. There is continuity between positive and negative plug holes in the back of the machine but not any between the ground and either positive or negative holes which I checked with a volt ohm meter. Do you have any ideas.
  • Sewing Machines Master
  • 1,564 Answers
Well, if it has continuity between pos and neg. But none between pole and Pos and pole and neg. What does that tell you? It's wired wrong. I would like to help you further but we don't know what kind of sewing machine this is. You didn't provide any of that information.
Posted on Nov 06, 2012
  • 13 Answers
SOURCE: Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Posted on Jun 23, 2008
bargainbox
  • 1388 Answers
SOURCE: euro pro shark 7132l no foot pedal/power cord
Sewing Service shops often have old foot control pedals from retired machines, so widen your local search and don't just look at Europro, as a good tech will service all makes.
Posted on Aug 02, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Viking 2000 SL and it seems
The first thing to check is the pedal itself. If you have a continuity tester you can check to see if a connection is being made in the pedal when it's being stepped on.
You can also turn the handwheel back and forth while you step on the pedal with the power to the machine on. If the motor starts to run a little bit, you know the pedal is good and the motor carbons will be bad.
That machine's rear cover over the motor comes off somewhat easily, so you could also check the connections in the electric terminal where the foot control plugs in. Make sure to have it unplugged when you do this part. Gently move the wires near where they connect to the terminal block and see if any are loose. There are screws there that tighten onto the wires that sometimes loosen which would make your pedal not work.
Posted on Oct 09, 2009
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Posted on Mar 24, 2010
  • 4 Answers
SOURCE: Power won't stop - Husqvarna/Viking 3600
Many older sewing machine (and some newer ones too) have radio-interference-suppression capacitors fitted in the foot controls to eliminate motor noise being radiated back down the mains power line. Many of these, especially the ones fitted across the rheostat (speed controller) in the foot pedal go partially or fully short-circuited, this meaning the machine starts sewing when the foot controller is plugged in. The solution is simple: get a qualified serviceman to take the capacitor out of circuit to see if that fixes the problem. If it does, then a replacement suppression capacitor of a suitable high voltage, at least 1,000V working, should be sourced and fitted. Just removing the faulty cap is not recommended and there is likely to be radio interfence spread all around the neighbourhood if you run the machine without the suppressor. The Radio Inspectors will not be amused. Good Luck.
Posted on Feb 27, 2012
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Foot pedal and power cord
also try sewvacdoctor.com for parts
Jul 12, 2013 | Kenmore 15218 Mechanical Sewing Machine
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
What's your problem?Have a TOYOTA EZT9000 and it seems to have slowed quite a bit. Does it need oil? If so, where do I put it in?
there are other things that can cause the machine to slow down
like the motor, foot pedal, have you checked these things first
1. is the power cord plugged into the outlet securely
2. is the power cord plugged into the machine correctly
3. is the foot pedal plugged into the machine correctly
4. is the cord to the foot pedal caught in the foot pedal
if none of these are the problem, then the machine needs to be serviced
to see why it's running slow
May 01, 2012 | Toyota EZT9000
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
Where can I purchase the power cord/foot pedal
you didn't mention the name or model of the machine,, but try ebay or
sewingpartsonline.com
Jan 31, 2012 | Euro-Pro Sewing Machines
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
My unit has no power to foot pedal. What are possible fixes?
change the power chord of your pedal, if not, open the pedal and look for the connection if that is cut or loose try to tight or connect it.
Oct 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
Singer 7462 sewing machine
There is two seperate cords on this machine. A power cord and a pedal cord. If you put the power cord in and switch the machine on, and then remove the pedal cord it should give you a beeping sound, which shows you the connection does work.
Please give me feedback in order to help you
Dec 08, 2007 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
