Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Spot bot keeps turning off
I have a Spot bot and it keep turning off when I try to do the auto spot mode. It runs for a few seconds and then turns off. The hose still works but not the Auto function.
  • rwj25 Jan 20, 2009
    Mine turns off after about 5 seconds and all the lights start flashing. Works fine on manual mode.
  • kansasccritt Feb 04, 2009
    My spot bot will run for about 3 seconds then start blinking and making a beep. help me.
reddevil6
  • 1673 Answers
SOURCE: Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator Please enter your ZIP Code: CANTRELL SUPPLY INC. 2918 SOUTH COOPER F-2 ARLINGTON TX, 76015 (817)465-9121 11.1 miles BRANCH VACUUM & JANITORIAL SUPPLIES, L.P. 12895 JOSEY LANE #122 FARMERS BRANCH TX, 75234 (972)247-5838 15.7 miles FORT WORTH SHAVER & APPLIANCE 1900 MONTGOMERY STREET FORT WORTH TX, 76107 (817)335-9970 16.3 miles AMERICAN VACUUM CO. 5545 W. LOVERS LANE DALLAS TX, 75209 (214)357-8419 18.2 miles KIRBY CO. OF DALLAS 4118 MAPLE AVE DALLAS TX, 75219 (214)526-7951 19.0 miles BRUNER KIRBY CO., INC. 5608 MC CART AVE. FT. WORTH TX, 76133 (817)292-8421 19.4 miles VACUUM DEPOT 5359 WEDGEWOOD FT WORTH TX, 76133 (817)292-4472 19.4 miles MODERN AMERICAN MAINTENANCE 8545 CAMP BOWIE WEST FORT WORTH TX, 76116 (817)244-0919 19.9 miles ALL VAC, INC 4451 LOVERS LANE DALLAS TX, 75225 (214)521-2558 20.2 miles KIRBY CO. OF DESOTO 104 N. HAMPTON ROAD DESOTO TX, 75115 (972)223-4029 23.8 miles AAA VACUUM CLEANER CO. 9845 WALNUT HILL LANE DALLAS TX, 75238 (214)348-1620 25.0 miles BROADWAY VACUUUM 4401 BROADWAY BLVD GARLAND TX, 75043 (972)240-7971 31.1 miles THE VACUUM DOCTOR 500 NORTH GALLAWAY - STE. 10 MESQUITE TX, 75149 (972)329-1104 31.4 miles CHAMPION VACUUM, INC. 8809 LAKEVIEW PARKWAY #128 ROWLETT TX, 75088 (972)463-2755 34.3 miles VACUUM & SEWING DR. OF TERRELL 811 WEST MOORE, SUITE E TERRELL TX, 75160 (972)563-0330 49.8 miles var prm = Sys.WebForms.PageRequestManager.getInstance(); prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity); prm = null; function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() { var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity'); var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter')); elAct.style.width = bounds.width + 'px'; elAct.style.height = bounds.height + 'px'; Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y); } Locating Stores... progressbar.gif
Posted on Feb 29, 2008
SOURCE: how can i clean the hose of my bissell spot bot?
Well... it's sub optimal but this is what I did, run hot water into the sink, add a few table spoons of bleach and run the hose along the edge of the water to slowly **** it into the hose (the tank fills very rapidly and the auto shut off will activate). You will want to run 4 or 5 tanks of waste to get the bulk of the gunk along the walls out and this will also get rid of the serratia growing (red stuff). If you dangle the hose in a u down the front of the sink and shut off the machine you can catch about a pint of water and bleach solution in the hose and roll it around inside the hose then let it sit for awhile and finish by sucking it into the waste tank, not perfect but my hose is much cleaner.
Posted on Jun 28, 2009
SOURCE: Need to clean hose.
I filled a bowl with hot bleach water and sucked the water up. It cleaned the hose pretty well (along with the gunk that was stuck in the hand wand). Mine was filthy. It looked like it had mold growing in it. Then I ran several rounds of hot water through the hose. I alternated hot water & bleach. Did this about 8 times. It is not perfect, but it sure does look a lot better. 90% of the gunk is gone.
Posted on Sep 03, 2009
SOURCE: clogged spot bot
There is a very small, white water filter (approx. 3/8" in diameter/ 1/8" thick) inside the "seat" where the solution tank connects to the machine itself. Could very well be your problem if you are in a city environment, or any other situation where hard water is present. This is a very easy fix; discovered it when my wife experienced the exact same problem.
1) Make sure other causes have been eliminated, such as clogged nozzles, etc. (Refer to owners manual.)
2) Ensure that the solution tank is indeed seating properly with the machine, (a few small bubbles rise from the connection once made.)
3) Remove solution tank. With needle nose pliers or a very small screwdriver, GENTLY remove the white filter from the black, movable "seat" connection on the machine.
4) Run the machine on manual (without the filter) to determine if this is indeed your problem. (Don't run for an extended period of time this way if this actually is your problem. The filter is there for a reason!)
5) Simply wash the filter gently between thumb and fore-finger. Vinegar may be used, but simple tap water works as well. If clogged, you should feel grainy, hard water type scale/ lyme build-up when cleaning the filter.
6) Recycle the original filter or replace if necessary. (It would be very easy to make a new one without going through the hassle of dealing with OEM parts or Bissell. Just go to your local hardware store and they should be able to help you out with no problem.)
Voila! Spotbot works again.
Hope this helps!
Posted on Feb 11, 2010
SOURCE: The hose on my spot bot has torn
I called one of the local service centres to order one 2 months ago, still haven't heard back. Last weekend was our city's curb giveaway weekend and I got a busted Bissell Pro Heat 2X Turbo which I removed the hose from. You can order them online, just not from Bissell directly.
Cut the old hose off, you won't need it.
You have to disassemble the unit mostly. Several screws on the bottom, several under the collection tank, etc... The tubing is held together with Brass tubing clamps, they're not glued. The inner hose needs to run inside, through to the outer channel underneath the 90degree bend that the outer hose plugs into and will connect to a T shaped 3 way hose connector. My hose was wider and needed the holes to be widened. If you have to use the same outer hose connector, the coiled hose will twist in, once you remove the old hose but the new hose will need to be siliconed or glued with something that will seal it.
My new salvaged hose had the handle on it already.
It's not a pleasant procedure, have a shower after because you may get sprayed.
That being said, this process is doable, but it isn't a 5 minute fix. It took about 40 minutes all and all.
Posted on May 23, 2010
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Need bissell spot bot oners manual
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 04, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
I need an instruction manual or booklet
I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
Need a Bissell Spot Bot Manual
You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
When I turn on the spot bot it immtediately starts beeping and won't stop
A sensor for the motor is malfunctioning. It is under warranty for a year.
Nov 28, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
The cleaning solution on my bissell spot bot is not being pumped through....on the stationary mode or the manuel hand held mode with the brush attachment
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Nov 07, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
Bissell spot bot
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Nov 25, 2007 | Vacuums
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
76 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
