Question about Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range
Hi want to remove top of smeg range to replace switch for oven
4 Suggested Answers
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
barterjoe
  • 338 Answers
SOURCE: can anyone supply a wiring
Looking at http://www.smeg-service.co.uk/support/index.php I have come to the conclusion that the best wat to have this problem resolved is to post it to the help forum or hire an engineer. Smeg has locked down any drawings. Take some pics and draw the wires and you might get someone to figure it out for you. Always remember that the company certified technicians can fix it the right way the first time ;)
Good luck.
Posted on Feb 26, 2011
SOURCE: smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Posted on Nov 13, 2011
How to lift a2 smeg cooker hob
remove cast iron pot stands and pull off all knobs and small timer buttons. lower the oven doors and look up under the panel holding the knobs and you'll see a screw at each end, remove them. you can now remove the stainless switch panel, (swing the bottom out first) you can now get access to screws at each top corner which should be removed. you can now lift the top panel of the cooker by about 5 inches when a pivoted stay should drop down each side to allow you to rest the top in an open position.
Oct 13, 2012 | Smeg A2.5 Dual Fuel (Electric and Gas)...
My wife was cleaning our smeg. She removed element at top of oven and she said it "arked". Now light inside oven and oven itself doesnt work?
Your oven should be wired to a dedicated electrical switch, in your meter box. It has probably just tripped this switch and fused the globe.
remove the globe cover(quater turn anti-clockwise) and globe and reset switch. Of course you need also to set the digital clock, or oven will not work.
May 02, 2010 | Smeg Ovens
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
My smeg oven,(bottom fan oven) keeps getting hotter and hotter till it cuts out or the fuse blows when i switch it on no matter what temp i put it on,iam assuming its the thermostat,were is it and how yo...
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Dec 12, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Mar 15, 2008 | Kitchen Ranges
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
I need users guide
I need to replace oven light bulb for  Smeg gas oven range cook unable to take cover off to get at bulb any ideas how this is done?
Oct 28, 2007 | Smeg SUK61MFX Gas Kitchen Range
Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
55 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
