Question about GE Microwave Ovens
GE sensor microwave oven DE68-02356A , Runs with door open?
Micro wave shuts off with door closed ,but when you open the door to take out whatever you were warming up,it starts to run again.
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave oven
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Microwave oven controls do not work
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
Posted on Feb 19, 2008
SOURCE: Internal fan on microwave runs with door open
I have the same problem with mine!!
Posted on Apr 11, 2009
  • 4088 Answers
SOURCE: ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Posted on Jul 16, 2009
My micro wave door opens n does not shut tightly I guess and so takes about ten tries opening n shutting before it starts. What should I do Panasonic inverter microwave (the genius prestige) Model...
The door is either out of adjustment, the door switches are out of adjustment, or the door/hinges are damaged. If the door switch assembly can be adjusted to fix the problem, then make sure the door closes as snugly as possible. As any repair to a door can increase the amount of microwave leakage, which can cause possible health issues for you, it might be wise to, at the very least, have a technician do a radiation leakage test on the unit once the door problem is repaired.
May 08, 2014 | Microwave Ovens
Genn-Aire JUMV 8208BAB door on microwave will not stay shut
try to adjust the latch, if not you must replace go to www.repairclinic.com and buy it
God bless you
Jul 16, 2012 | Microwave Ovens
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
Stuck door latch
no call a tech micro-waves can be dangerous to work on
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Problems with the fan EMERSON MW8107WA
I still suspect a bad door switch or door switch mount, but it may be a stuck relay or bad conneciton on thew control board.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 26, 2007 | Microwave Ovens
Microwave Ovens Logo
139 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
