Question about Lenovo Computers & Internet
Need program to enable communication between pantech & pc
  • 3 Answers
Assuming you have a cable already, this should work as its from Pantech.
http://www.pantechusa.com/support/download/cJyq3SuiIwuObXWU9a7sA0wcmaXwB8BLJCxeEH9PbSIDjR452AtE7UztMshol8U-
Posted on Oct 25, 2012
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
How do i set the time on a pantech p5000?
Date and Time Settings - Pantech Marauderâ„¢ [Device-Specific Instructions]
  2. Select Settings.
    1. Select Set date.
    3. Select Set time.
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Pantech ease 2020 photo transfer
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain something that looks like PTQH_V1_1_4583_1215_SETUP - Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Apr 23, 2012 | Pantech breEZeTM Cellular Phone
Purchased a USB cord to download photos from my phone. Can I use it without having a disk to install it into my computer?
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Dec 08, 2011 | Pantech Cell Phones
How do I down load photos to pc
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to "Program Files" on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the "Program Files" folder on your computer. Then open the "Pantech" folder. Next open the "Pantech PC Suite" folder. Now open the "P2020" folder. Finally open the "USBDriver" folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this is a helpful solution for you.
Dec 08, 2011 | Pantech Ease P2020 AT&T
Pantech pc controle suit
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to "Program Files" on your computer. You need this software before you will be able to connect with your phone. If this download does not work on your computer it could be that it is not able to get past your security or firewall settings. If you still can not get it to download I would go to another computer and transfer the program for that computer to yours with a USB flash drive. (2nd) after you download this software you need to go to and open the "Program Files" folder on your computer. Then open the "Pantech" folder. Next open the "Pantech PC Suite" folder. Now open the "P2020" folder. Finally open the "USBDriver" folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this is a helpful solution for you.
Nov 22, 2011 | Pantech Ease P2020 AT&T
I have a pantech p2020 ease and i cant get my computer to recognize it..
Mar 12, 2011 | Computers & Internet
My pantech ease won't send pictures.
Jan 10, 2011 | Cell Phones
Pantech c300 data cable use
Apr 03, 2008 | Pantech C300 Cellular Phone
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
