What does F72 and F22 mean on vaillant boiler codes
2 Suggested Answers
SOURCE: f22 on my vaillant boiler turbo max
Hi Guy's,
The answer is that your system is out of water pressure.
Usually there is a nob on the right under the base of the unit near to the small dial to the right of the front cover.
To enable the system to work correctly the needle on this dial should be in the Grey, about midway position.
Currently with fault F22 this will be lower to below the Grey and on the needle.
To bring the pressure back to the correct position, you need to turn this nob until you hear the water entering the system, KEEP AN EYE ON THE DIAL AND TURN THE WATER OFF AGAIN WITH THIS NOB ONCE THE DIAL IS IN THE CORRECT GREY POSITION AS MENTIONED ABOVE. DO NOT OVER FILL THE SYSTEM. I suggest you check this every six months or so.
Once this is corrected your unit will light up again.
Best of luck. Mike. N.
Posted on May 22, 2009
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
Vaillant error F22
The water pressure is too low. Set it for 1.5 - 2.0 BAR.
Mar 05, 2014 | Computers & Internet
My valliant combi boiler 4 years old wont start up fault code 22 flashes up
F22 means low water pressure. Check the pressure dial on the boiler and adjust using the link pipe and valves.
Nov 15, 2013 | Computers & Internet
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Dec 04, 2012 | KDS Valiant 6380iPTD-01 Notebook
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
F22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
May 11, 2010 | Heating & Cooling
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
F22 on my vaillant boiler turbo max
Hi Guy's,
Feb 01, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
Computers & Internet Logo
1,639 people viewed this question
David Payne
David Payne
