Question about Coby Electronics Corporation Coby Kyros MID8042-4 8" 4 GB Slate Tablet - Wi-Fi - Allwinner Cortex-A8 1 GHz
Removing demo app from the coby tablet mid8042-4
There is a demo app that pops up every time. I tried going into setting and delete it but there is no opp to do that. I also have done a factory reset and nothing still there
I cannot delete my apps
press on the apps icon you want to delete for a few seconds until you see it shiver
press again and it is gone
Nov 14, 2015 | Tablets & eReaders
How do i get my axs trio tablet out of demo mode and user terminated?
It happened to me also after I clicked on Trio Watchdog just to see what it does. Immediately I stopped the app and "removed" it, but although it disappeared from the App list obviously it was still hidden somewhere. Could not use SETTINGS to see it running and stop it because SETTINGS will not stay up also, same ....demo message.
The solution, for me, was to open the factory loaded App Permissions app and go to the startup section where I unchecked Trio Watchdog. I than rebooted the Trio AXS tablet and was back to normal.
May 24, 2015 | Tablets & eReaders
How do I remove demo mode off my tablet
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Mar 26, 2015 | Acer ICONIA Tab A500 10.1 inch Tablet PC,...
How do I delete an app with an X whin I tap delete it never deletes
Some applications are built in to the device's firmware and cannot be removed. If you are trying to remove an app that you installed yourself and you cannot uninstall it through the application manager (Android) or control panel (Windows) then you should contact the developer you acquired the app from.
Dec 31, 2014 | Tablets & eReaders
Demo mode will not shut off in lower left corner
Please follow the below mentioned procedure to disable Demo Mode in Acer Iconia Tablets.
Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
Regards
How can get out from Iconia A1 810 DEMO Mode
Nov 10, 2014 | Acer A1-810-L888 8-in 1024x768 LED...
How to disable demo mode lg 55ln5750
On remote Press SMART (with house symbol)
go to
settings then
option then
mode setting then select
home use
(and, if you're feeling really brave, but it's not necessary to do this to remove demo mode
to return to initial settings
SMART
Settings
OPTION
Initial Setting
Deletes all optional settings and returns to initial default mode.
Once initialization is complete, the TV will turn off and on by itself.
If Lock System is activated, a pop-up password prompt will appear.
Do not turn off the power during initialization)
Jun 27, 2014 | Tablets & eReaders
How to stop demo mode
Go to APPS mode. Find DEMO MODE. Click on it and follow the indicators to disable it.
Sep 21, 2013 | Acer Iconia B1-710
Wifi won 39 turn
you have to do is be root and install an app called root exploret
and go to system / app here find the application to be deleted and if you go back to the menu and restart the tablet is removed and you can download the update hope you reserve
Aug 31, 2013 | Iview Cyberpad 900TPC 9-Inch Tablet
Coby kyros 8042 manual
demo app keeps popping up. i have reset, eeboot, wipe, deleted, cleared, called coby, etc,... to no avail. please assist if you can. i vsnt even grt through a few pages of a book with out it popping up on me. help
Jul 29, 2012 | Tablets & eReaders
Coby Electronics Corporation Coby Kyros MID8042-4 8" 4 GB Slate Tablet - Wi-Fi - Allwinner Cortex-A8 1 GHz Logo
127 people viewed this question
Top Coby Electronics Corporation Tablets & eReaders Experts
Stan Ford
Rigger
Brenda Magallanes
Brenda Magallanes
Are you a Coby Electronics Corporation Tablet and eReader Expert? Answer questions, earn points and help others
