PC starts then shuts down will not boot - Computers & Internet
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Oct 26, 2012
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
Can't boot system shuts down immediately
The hard drive has failed and needs replacement.
Feb 23, 2014 | Acer Aspire 5742Z-4200 Notebook
I have a dx6100 which does not boot because of the red light that keeps on beeping.
sounds kinda like a memory shut down code beeping or hardware shut down take side off and start unplugging hardware devices 1 at a time and try rebooting until it starts up
1st take memory sticks out and just put 1 of them back in a slot at a time and see if it will boot
Jan 12, 2011 | HP dx6100 (PE280ETABB) PC Desktop
My computer fails to boot. I shut it the normal way and now doesn't get past basic start up.
press f8 button many times when you start the computer, it will take you to the options where you select boot by safe mode. In this way you will be inside your windows. Once inside, shut down the computer in the normal way. once shut down now restart the computer in the normal way. If it does not start, you need to change your windows.
Sep 18, 2010 | Computers & Internet
Push the start button and start up begins but then shuts down after 10-15 seconds. Push again and the duration between start up and shut down are shorter intervals. Pressing F8 will bring up the safe mode...
You need to determine if it is hardware or software. Try booting from your restore CD. If the unit will boot from the CD then you just need to repair your OS installation. If it will boot from the CD then try going into BIOS setup. If you are able to access the BIOS leave it in there for about 1 hour to make sure there is not a hardware issue such as an overheating CPU.
Open the cover and remove all of the "Dust Bunnies" that are collected inside the case - look closely at the cooling fins of the CPU if they are clogged your CPU will shut down to prevent damage. I use a tooth pick to clean out the fins of gunk - especially if there is a smoker in the house
Jul 28, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Sony vaio boot up in normal mode
boot to the repair partition and reinstall windows it sounds like a registry problem reinstalling should fix
Aug 02, 2009 | Acer Aspire One Netbook 8.9" Notebook
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
The PC doesn't completely boot up
u shoudl use xp cd and boot in formatt hard drive fresh install of your os
Jan 28, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
David Payne
David Payne
