Question about Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V
Ground wire shorted off at wlder
Burned off connection into machine.Also having problems with groud wire getting hot and burning apart.
Tail lights go on then after a short while they are off all other lights stay on
Double check owner's manual, troubleshooting. Sounds to me like an issue with connections most likely at the switch, bad switch, or possibly a ground that serves the taillight assembly. Do all lights in the taillights go out? Brake, turn signal, parking, and Backup? If so more than likely the "ground wire" that serves the whole tail light assembly serving all the above-mentioned lights is apart or bad connection. It's an uninsulated wire that "should" be attached to the body metal with a screw. The attaching screw, or body metal may be rusted at that location resulting in a bad connection. Clean to bright metal both the location and lug. there may be a similar connection issue in the Taillight assembly.
Mar 05, 2015 | Cars & Trucks
2000 jeep grand Cherokee limited only blows cold air despite c.c setting position. Also what I'm Guessing to be the blower control module hot lead burned through end of wire/ wiring harness/ and circuit...
lead burned through
that's easy
using the wrong fuse size
and the feed is shorted,
the correct fuse prevents the burned wires.
here are the HVAC pages
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
lots of things can short. in cars. (topic Hvac)
  • the wires.
  • the connectors
  • the HVAC motors (actuators)
  • the blower.
if you had stated the exact wire color and what it connect to exacty
we can state who shorted.
Fuse 1 , 40amp runs the blower. dark green.
Fuse 20 , 10amps runs others.
Fuse 7 runs zone control,,,10A and all 4 damper motors actuators.
see 8w-42-6 pages.
ok you have your FSM and now can find who connects to what.
Apr 10, 2014 | 1999 Jeep Grand Cherokee Limited
Hello. Please help...Ive never owned a diesel and quite unfamiliar with them. Ive been having to start the truck lately by jumping the starter relay at the fender wall. So installed a new one. Apparently I...
Lets start with make model and year.
And for the record, you will likely need to tear apart that harness because the other wires are now melted together.
Aug 10, 2013 | Cars & Trucks
I have a 350 engine gmc 1977 went to put new connecters on the wires to the alternator and one of wires touch the header and sparked i had my battery still connected daa now i have no power at all, what...
your hot wire was grounded when it sparked, it burned the fuse involving that circuit to protect from a short , just replace burnt fuse inside of fuse box.
Feb 19, 2012 | Cars & Trucks
My mig welder will not make an arc
There is a small chance the transformer burned out, but more likely the switch has dirty contacts or burned out. If you turn the switch through all heat positions 2 or 3 times before you start welding in the morning, it should remedy it in the future. In the short term, spray some contact cleaner (or even WD 40 in this rare instance) into the heat selector switch and rotate it through the ranges a number of times to remove corrosion from contacts.
Will the wire arc when dragged across the ground clamp? If not- there are internal fuses in the machine and they may be loose or blown. There should be one in series with the "hot side" (the gun) of the circuit and sometimes on the ground clamp side of the circuit.
There is a small chance the transformer burned out, but more likely the switch has severely corroded or dirty contacts or the switch burned out.
Jan 03, 2012 | Welding Tools
'95 Bonneville SSE won't start
Check for a burned out fusible link at the junction where the positive cable bolts to a stud.1994-1995 may be on the starter,connected to the large hot cable on starter.The fusible link,if burned out will pull apart like taffy.It looks like a regular wire,but like I said,it will pull apart like taffy,if it is burned out.Replace them with the same size fusible link,not a wire,you wil set the car on fire if you do,and there is a short.After you do this,check for a possible reason this link burned into,something caused this.Low battery,or bad starter,plus holdind the kay in the start position trying to start the car with a low battery,or bad connection,or bad starter,will cause tis problem.I hope this was helpful.
Oct 06, 2009 | 1994 Pontiac Bonneville
!998 chevy caprice classic starter solenoid wires are burnt
check all wires for bare spots and ensure all grounds are good .probably have short
Jul 10, 2009 | 1991 Chevrolet Caprice
I have a 1999 jeep cherokee 4x4 4.0L I6. I was having problems starting the jeep it would crank but not start right away. if I would crank for 3 or 4 cycles then stop then turn key again it would fire...
If you had a short that large before you started working on the batt cables, it would have burned long before it did. Check your work over and see where it's grounding. You can make a temporary link by using a new piece of wire the same as the gauge at both ends of the link and sectioning in a short piece of smaller ga. wire. Hopefully you didn't damage the alternator or other electronics. The original problem sounds like possibly the fuel pump anti drain-back valve is bad (integral with pump) Testing pressure will verify that.
You can disconnect alternator, but the fuse method you mentioned sounds more reasonable.
Jun 14, 2009 | 1999 Jeep Cherokee
Wont hold charge in expedition
  1. Check the wiring of the new radio installed as follows..
  2. Disconnect battery ground
  3. verify radio ground wire is grounded to metal
  4. verify radio hot wire (normally red and thick) is connected to a power source that is off when the ignition key is in the "off" position.
  5. verify that the always hot wire is connect to a constant 12v power supply even with the ignition off.
  6. make sure the pwr antenna wire if not used is taped at the tip and not touching any metal.
  7. verify that all speaker wires are connect correctly and not shorted to ground.
  8. connect battery ground you may get a small spark if your courtesy lites work.
  9. start engine verify your battery is charging by disconnecting the battery ground cable while the engine is running, it should continue running if it don't, alternator maybe bad.
  10. If it continues running problem solved..
Nov 11, 2008 | 1987 Ford F 350
Electric radiator motor shorted to ground and burned wiring from motor thru harness. fusible links also. to get home bought new fan/motor assembly and wired hot to run all the time. My problem is what to...
yes you can get a new wiring harness,from your plymouth dealer, or junkyard. its best to get a new one because they always are improved from the original.
Jul 28, 2008 | Plymouth Sundance Cars & Trucks
Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V Logo
29 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
