Question about Samsung DV316LGS Dryer
Dryer will blow warm barely or cold air
The lint is clear
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
Takes 3 cycles to dry clothes
This is a potentially deadly scenario. If the clothes are warm but just not getting dry, there is a problem with air flow - specifically - the lack thereof. The chance of fire is a real concern.
Make sure the lint baffle / trap is clear. This should be checked / cleared after each drying cycle. Most folks know about this, but I included it just in case this is your first dryer.
If the the baffle / trap looks clear, the exhaust tubing of the dryer is suspect. Many installations consist of the flexible / expandable hose. This hose may have become crushed during the running of the dryer, reducing air flow. Locate the hose and pull the dryer away from the wall to inspect, expand or replace the hose as needed. If an old installation, it is very possible that the hose has become clogged with lint build up over the years. The hose should be replaced in this case.
If at all possible, use aluminum expandable dryer duct. It is less likely to collect lint as quickly as the flex plastic style.
If the clothes are not warm or hot, the heat source (electric heating element or gas flame - depending on type) has a problem. Either of these problems should probably be referred to a pro for proper repair.
Jan 20, 2010 | Kenmore Dryers
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Maytag MDG16PR gas dryer produces only warm temperature
you could have a blockage of lint either in the dryers front bulk head (where the lint screen is) or you could have a blockage somewhere in the vent line. check those and if you have a blockage remove it and that should clear up the problem
Oct 20, 2008 | Maytag MDG16PR Gas Commercial Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Samsung DV316LGS Dryer Logo
26 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
