Question about Sharp 27H-S60 TV
Color Turns Green
I have a Sharp 27Hs60 and sometimes, while watching the tint turns green. Sometimes when I change the channel it pops back to normal color, but then goes back to Green again. Is this a minor adjustment(there are limited color control options in the menu) whats up? Please help. Thanks, AndrewL
    Problem Solver:
  • 7 Answers
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
Posted on May 22, 2008
The tv was giving as a gift in 2012. So I believe that I put the right model in. I was watching the tv and went to change the channel, when I noticed that the box with the channel number looked differ
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
Oct 21, 2014 | LG 32LD450 32 In. LCD HDTV
My flat screen hd sharp aquos color turns green when we are watching it. it is only 3 three years old. what can this be? thanks
I'm not sure if this is the same, but people were green no matter how i adjusted the tint, and lacked overall color. I doubled checked the component cables, taking each one out, and putting it back firmly,
Picture is back to normal. Easy fix.
Feb 10, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sometimes has green tint.
YOU ARE 100% CORRECT it is the cameras ....... as a tv camera wears out green is the last to get weak . so the picture turns green crt tvs do the same thing
Mar 25, 2009 | Sony Televison & Video
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Green tint
Is the green color on displays as well. (Displays means the video generated by changing the volume or activating menu-and seeing if this is green as well. Secondly, turn the color all the way down to zero. Do you see a "normal" black and white picture? If you do, then the picture tubes are not the problem and you have a failure in the color processing area. Let me know....
Mar 07, 2008 | Hitachi 51F500 51" Rear Projection...
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
340 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
