Question about Toshiba Satellite A205-S5853 Notebook PC
2003 corolla No compression. Changed timing set. Still the same. What's wrong
Car jumped time. Sounds like it has no compression. Changed the timing set. Still sounds like it has no compression.
  • Glenn Tyrone Fielder Oct 25, 2012
    This question is not for the lap top. Disregard
  • joecoolvette
    joecoolvette Oct 25, 2012
    As stated needs to be posted in the Cars and Trucks category. However just to add my 2 cents since it did wind up here; It may be an 'Interference' engine. Zero clearance of the valves to pistons. If timing skipped, valves could be bent. Hence no compression.
  • 14,417 Answers
Although the 5S-FE and 7A-FE engines are not listed as interference motors (it is not listed by the manufacturer as a motor whose valves might contact the pistons if the camshaft was rotated separately from the crankshaft) Check your piston rings,did plugs have oil on them.
Posted on Oct 26, 2012
Husband car slowed down on highway. Wont let him go 60 he has to pull over and park car what's wrong with it? He just had timing belt changed and oil leak sealed.
The first thing I would have checked is the cylinder compression. When things just "happen" it is often related to the most recent maintenance performed. By doing a compression check, if the cylinder compression is low, that would indicate that the timing belt slipped or jumped time, indicating something was installed, adjusted, or tightened correctly. If the compression is good and even on all cylinders, then you need to look for other possible problems.
Sep 25, 2015 | Cars & Trucks
Speedometer jumping up and down and car will not pick up speed.
Based on your actions, it sounds like a wiring problem.
Could be a weak connection at the cluster, or the speed sensor.
Apr 09, 2013 | 1994 Toyota Corolla
Changed serpentine belt still not running, checked timing belt, it looks fine. checked compression, read 20, 20, 40, 20psi, from left to right if looking from front of car.... help.
If the spark plugs were fuel fouled, you could have washed the oil off the cylinder walls causing the low compression.
Or the cam timing could be off because the timing belt jumped a few teeth, or the cam gear broke.
I would pull the fuel pump fuse or relay and try to dry out the cylinders first.
And re-check the timing belt. The serpentine belt would not have any connection to the car not starting.
Sep 28, 2012 | 2003 Ford Escort
Loud exhaust
Hi
Loud noise from Exhaust means your exhaust system is leaking.
this will make the performance poor on your vehicle.
Get that check and replaced.
Jul 31, 2017 | 2003 Toyota Corolla
I have a 2003 Chevy cavalier that will not start or even try. It cranks fine, I have verified it has spark, I replaced the plugs and crank shaft position sensor, timing chain is intact, but I didn't...
you may need to check the compression. if the plugs have fuel on them and you know the spark is good then the only thing missing for the car to run is the compression. if all the cylinders have low compression then the car has jumped time most likely.
Aug 08, 2011 | Chevrolet Cavalier Cars & Trucks
I have an 03 Toyota Corolla "S" and it was running fine then an hour later I go out to start it and it don't start. All you hear is the fuel pump and just one click. Whats wrong?
sounds like your starter is going bad. check the battery connections first. make sure they are tight with no corrosion. Maybe your battery is getting weak. try a jump start. You can have both tested at most auto parts stores.
Sep 19, 2010 | 2003 Toyota Corolla
2003 Ford Escort ZX2 2.0L engine knock and no power.
Get yourself a compression tester and remove all spark plugs and proceed to check the compression for this motor the readings should all be above 110 psi, the car may have jumped a tooth on the timing belt and requires a new belt to be installed.
Aug 07, 2009 | 2003 Ford ZX2
CAR WON'T START
yea sounds like u need a starter i think on that model its located behind engine under intake manifold u have to jack car up high to work easier there's 2 bolts holding it in and if i remeber correctly 1 is tough to get at if iam wrong on location just follow positive cable from battery and you will find it
Apr 01, 2009 | 2003 Toyota Corolla
Timing settings
my jeep has jumped time and i need to know the exact degrees to set it at please and thank you.
WRONG!!! WRONG!!! WRONG!!!
The first thing you need to do is to find out why it jumped time. Jumping time is not normal and shouldn't happen.
Tell me the last repair that was done on the jeep.
When was the timing belt last changed?
Were OEM parts used?
Were tensioners and pulleys changed?
Dec 27, 2008 | 1995 Jeep Grand Cherokee
Toshiba Satellite A205-S5853 Notebook PC Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
