Question about Crosley 4-in-1 Entertainer CD Shelf System
Crosley stuck in hello mode
I plugged the system in and it says hello and stays in that mode
"problems with turning on crosley cr2405a, just display "HELLO""
make this test. There may be a system lockup caused by static discharge. Unplug the power cord and plug it back in.
God bless you
Jul 27, 2013 | Audio Players & Recorders
42' Crosley lcd tv wont come on
There is some fault with its digital processor board [main board] Contact any experienced service technician. This is not a user repairable one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 07, 2013 | Crosley C42hdgb
CD's won't play. The counter stays at "00" & the LED light above the play buuton stays off.
I never have trouble playing CDs on a similar Crosley system, but you might want to first try playing a disc that you purchased at a store. It may be possible that your system cannot play some formats of burned discs.
Apr 12, 2011 | Crosley CR-74 Shelf System
Cannot get my new crosley out of standby mode. which button do you push as there is no standby button?
When it is off and plugged into the wall outlet the standby light will be on. The stadby light will go off when power button is pressed. If not there is poblem that needs service.
Dec 26, 2010 | Crosley CR78CD-P CD Shelf System
Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Sep 04, 2009 | Crosley CR247 Shelf System
Stuck in hello mode.
Take top off.....look for a buldged capacitor on the circuit board that the power cord comes into first. That was my exact problem, and that was my exact solution. Just un-solder the blown capacitor, go to radio shack and buy a new one for $1.
Jun 23, 2009 | RCA DRC8335
When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Jun 02, 2009 | RCA DRC8335
My computer is stuck in power save mode how do i remedy this?
Hello!!
Goto system restore and restore ur PC to earlier date and restart .. it works!!! Thank you!!
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Sep 19, 2008 | Crosley CR248 Turntable
Crosley 4-in-1 Entertainer CD Shelf System Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
