SOURCE: need code for matsui lm37hd1 for urc-1625
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
SOURCE: bought urc-7515 code 0037 for bush telly only
The original remote for a Bush uses several codes for various buttons! I doubt that many of the universal remotes would have the sohistication to do this. Does your remote provide a 'Learning mode? If so this is the only way to get it to work close to its original.
SOURCE: what is the code for ONN digibox one for all
Hi
i had the same problem, in the end i went through some codes at random (using the codes in the back of the One For all manual).
Dropped lucky and discovered that the Alba code 1284, worked for me. All remote functions worked spot on.
Hope this helps.
SOURCE: cant get omega urc-04-1 remote control to work with my alba tv
URC, if you have the manual, will tell you how to do a manual search for the code rather than a specific code entering. The codes that are listed are not always the only codes that work with the TVs.
