Question about iRobot Roomba 530 Robotic Vacuum
What is era 6 and how do you solve it - iRobot Roomba 530 Robotic Vacuum
  • iRobot Master
  • 18,409 Answers
I have a euralab robot vacuum and it is only lasting about 5 minutes before it runs out of power. I have had it for about 2 weeks and it worked well at first
I can't guarantee that this will solve the problem, but try deep cycling the battery.
Run the robot until it stops completely and uses all of the battery charge.
Charge the battery until fully charged. Let the battery cool for 6 hours.
Repeat and see if the battery life improves.
Repeat this charge/cool/discharge cycle 3 to 4 times.
Gary
Jul 15, 2011 | Vacuums
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
Where can I buy a replacement battery?
I found a good deal on ebay. Didn't want to pay Dyson's battery price.
I love my Dyson handvac. I'm very happy to have it back again! The new battery solved the problem.
Jan 27, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 | Vacuums
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Parts for Electrolux Epic 6500
You need to look under AERUS Electrolux to find a Dealer with parts.
Electrolux USA sold the brand name back to AB Electrolux of Sweden a few years ago and there is no relation between the two.
You may also find a common component of a different color at a Tri Star dealer as they shared some power head and hose technology in the era of the EPIC although they don`t tell people that
Sep 14, 2009 | Electrolux Epic 6500 Vacuum
Kenmore vacuum model 116 3592250 is not sucking nor is the brush turning
If the brush is not turning then you need to check to see if the belt on the inside is broke.There is 4 to 6 screws that you need to take off.Depending on the model,there should be 2 screws in the back at the base of the vacuum.Then there is around 2 more on the bottom of the vacuum.Take those out and you will see the belt on the right side.Change that and it should solve your problem.
Aug 30, 2009 | Vacuums
iRobot Roomba 530 Robotic Vacuum Logo
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
