Question about Samsung SF-560 All-In-One Laser Printer
Fax machine not working
It displays the Memory receiced 95%
    Problem Solver:
  • 13 Answers
Wipe the system memory or it could be jammed
Posted on Oct 25, 2012
  • Aleesha Oct 25, 2012
    How do I clear the memory. I am do not have an maunal or anything to go by... I also check to see if it was jammed I cant see that it is at all.
Model Fax 1840CZ
Please send email to LBrown18062@hotmail.com and I send you manual. Put "brother fax1840c" as the subject.
Feb 17, 2012 | Brother Office Equipment & Supplies
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
TAD error
Change the RECEIVE MODE to FAX ONLY. TAD stands for telephone answering device which is used if one of this device is attached the EXT port.
Dec 08, 2009 | Brother IntelliFAX 560 Plain Paper Fax
When i press hook to receice a fax the message continues to read
Check that the tel line cable is connected to the correct hole in the nachine. It may have been moved. It should be in the one marked 'L' or 'LINE'. Use another fax lead to see if the lead is faulty. Otherwise you may have a faulty LJU board which requires replacement and will cost more if not on warranty, than the machine is worth.
Jul 06, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
Sharp UX-117 display Wait a moment on power on and then no signal
I have not worked on a sharp ux-117 before, however most sharp fax machines are all alike when it comes to resetting this code. Turn the fax on while holding down the stop and start key don't let go until you see 1 =yes, 2=no for memory clear. press 1=yes. Some of the sharp fax machines have a small white rounded reset button. No guarantee but you have nothing to lose.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Fax error cant receice fax
For Troubleshooting:
Disconnect all equipments using the phone line
Connect the FAX directly to the wall jack
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Fax-2820 "out of memory" indication
The memory is full. Either because the machine is out of toner, or out of paper, or that there is a fax broadcast in memory that has not completed yet.
May 11, 2008 | Brother IntelliFax-2820 Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF-560 All-In-One Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
