Question about HP Photosmart 3210 All-in-One Printer Copier and Scanner
Hp photosmart starts and blocks, error light also starts blinking
Its brand new, i'm about to use it first time but this thing hangs right after start, it asks to "load paper in tray" and press ok, i did it, then it says "start initialization" and press ok, but it stuck with this massege, and do nothing ;P what can i do for this??? please help me out.... thanksss a lotttttttttttttttttt.
  • Tech. Future Point
    Tech. Future Point Oct 25, 2012
    thanks but it didn't work for me! i check and reconnect all but nothing... :(
  • 54 Answers
Try to check all the necessary parts so that you will know what to fix and keep everything be detailed on managing certain things that will inhibit creativity.
Posted on Oct 25, 2012
Missing or failed printhead on first time installation
Install old cartridge,& chk..
Same error? : Problem with the printer.
Low ink error? : New cartridge faulty, claim it for replacement
Mar 18, 2013 | HP PHOTOSMART 7520 E-ALL-IN-ONE
Hp photosmart won't print in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 10, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Error message stating empty cartridge but I bought it new today
sometimes it does happen. please carefully try it several times and try to doing it in different manner.
you can try wiping out dirt and other things that can prevent the print cartridge from functioning ..
you can even disconnect the printer cable from the pc while trying to fix the cartridge, and checking the cartridge installed light to know if it's right.
thanks for your question..
May 20, 2009 | HP Photosmart 8250 InkJet Printer
Can't turn my HP D5460 off
To turn off the HP D5460 Photosmart is by pressing the ON button located on the product. Wait until the on light turns off that mean it's off.
Apr 12, 2009 | HP Photosmart D5460 InkJet Printer
Hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Mar 29, 2009 | HP Photosmart C3180 All-In-One InkJet...
Incompatible Ink Cartridge notice with proper HP ink
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74 / 75 (or 74XL/75XL) cartridge(s) are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Dec 12, 2008 | HP Photosmart C4280 All-in-One InkJet...
Open Questions:
HP Photosmart 3210 All-in-One Printer Copier and Scanner Logo
Seeker5211
Seeker5211
