Question about Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual
Where can I get a 12V manual reset relay which requires reset after a power failure during the on setting?
I'm upgrading (safety-grandkid use) a Delta "Q3" scroll saw by using a 12V battery source with the saws blade integrated in the circuit to a relay controlling 110V line power to the saw so that a broken blade will shut off the saw. To complete the safety function (preventing automatic restart when a new blade is being inserted in the blade clamps- if the relay switch is left on) I need a 12V manual reset relay so the saw will not restart after a broken blade unless the operator actuates a restart button/switch. What is a commonly available (simplest) device to do this?
  • 412 Answers
Get an ordinary 12v single pole relay. Connect your 12v battery source to one side of the coil (-) and one of the contacts (+). Then connect the other side of the coil (+) to the other contact, and your output cable across the coil. Of course, nothing happens until you connect a pushbutton switch ACROSS the two open contacts. When you make that switch, you power the relay, and it stays powered when the contacts close. It's called a "seal-in" relay. When you interrupt the battery power, the relay falls out and won't pull in again until you hit the reset switch.
Posted on Apr 23, 2017
  • 1996 Answers
SOURCE: manual or info on a rockwell 28380 14" band saw
I can't find one for the exact model number you have, but there are a lot of manuals for the same era bandsaws available as PDF downloads at this site. Perhaps another manual for a similar machine will help answer most of your questions, in lieu of the correct one...
Have a look around there, though, at both the Delta and Rockwell listings, as I just made a quick look to find yours and there might be something there somewhere.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
  • 1996 Answers
SOURCE: I need a manual for the Delta band saw model number 28-207
Go to this link, Right click on the underlined PDF below the Publication Preview, and you'll be able to save target as a pdf file onto your system.
Posted on Aug 05, 2009
  • 1996 Answers
SOURCE: I need a manual for an old Sears Band Saw Model #534.01120
Does it look like this? Unfortunately, they don't have a manual that I could find. But you might like to post your request in the forums there, as they get some traffic from aficionados of old tools with wile and know how.
It might help you also to google Dunlap & PowerKing for the manual.
As far as tuning it up goes...
Check each of the wheels' "bearings" to begin with, to ensure they are running smoothly and as true as possible, without end play or wobble. Then use straightedges and flat jointed boards to line up the three pulleys as much in a single flat plane as possible, by shifting shims, etc. (It may behoove you to remove the table out of the picture to begin with, if possible, so you can get the wheels lined up well with one another, then replace the table once the blade will track.)
The adjustments on a three wheel system can be a little more delicate and temperamental than on a standard 14" bandsaw, so be moderate in your tracking adjustments, and crank the wheels by hand to begin with as you work the tension up on the blade, checking constantly to keep the blade running as close to the center of all three tires as possible. Don't worry about the blade guides at all until you get the blade running on the wheels well. Then move the backed off guide blocks and backing bearings into place. They are meant, after all, to keep the blade from deflecting, not to force it into position.
That's my quick advice for how to tune it up.
Good luck. It looks like a beaut!
Posted on Sep 03, 2009
  • 7733 Answers
SOURCE: I've just used my 9" Delta bandsaw a couple of
The blade has too much adjustment.Go to your user manual or Look at and the parts diagrams
Posted on Nov 08, 2010
SOURCE: I need an owners manual
I have a manual and parts list for the 34-625
Posted on Feb 25, 2011
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
No 12v output from aux terminals on a vfx 3648
Pretty sure it won't provide current to start anything. Just provides 12vdc at a low current to pull a relay in.
Manual say it is auto reset on the aux terminals for the generator start relay. 0.7 amps max.
If you still don't have the voltage there at the correct time (when called for), you unit is bad or has a fuse they don't mention in the manual. Remember!! This is a called for function so the voltage will not be there all the time, just when required as per the programming.
Oct 26, 2012 | Wss Pre-Wired VFX3648 Outback Flexware...
Location of the fuel pump reset and how to fix it?
There is no fuel pump "reset"(that's a Ford thing).You could have a bad relay,a broken wire or something else.The easiest place to diagnose is from the fuel pump relay socket.You can verify the high current 12v feed,the 12v ignition feed,the switched ground from the PCM,and ohms to ground to the pump from this single location. You will probably save time by trying another relay first(borrow the AC compressor relay from its socket-same part!).
Oct 07, 2012 | 1997 Buick LeSabre
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a 1995 ford f50 that will not start with the key. Replace ignition switch, clutch interlock safety switch, starter relay on the passenger fender. I can manually jump start by crossing the pole s at...
Check the small wire going to the starter relay. It should have 12V when the ignition is in the start position. If it doesn't, you either have a bad igntion switch or a wiring problem from the switch to the relay. If you don't have a volt meter, you can use a 12V test light. Let me know if you need more help.
Aug 25, 2011 | 1995 Ford F150 Styleside Regular Cab
I gave my grandkids my husband's old Tasco Reg No.
All of Tasco's manuals are on this web site:
May 21, 2011 | Tasco Optics
My power windows do not work. The Haynes Repair Manual mentions that it could be that a circuit breaker was tripped and might need to be resetted manually. Where and how do I manually reset the circuit...
i have diagram for accord 1993, i cant see the breaker you mentioned, if your relay is ok, its mean that fuse #15 have power 12V and when the ignition is on, the relay have supply 12V to fuse #33, if all this ok, the problm is on your power window main switch, connect a wire supply by 12V to white/yellow wire at power window main switch or test this wire if already have 12V when ignition is on
Jun 26, 2010 | 1993 Honda Accord
I have a 2000 Jeep Cherokee sport and it just won't turn over. It has full power inside and a brand new battery.
You need to begin testing at the battery using a volt meter. Power requirement of interior is far lower than the starter needs. Check battery for 12v, check that posts & terminals are clean and secure, Check starter relay in the power distribution center, make sure grounds are good at the engine end. Check for 12v at the starter main terminal and 12v at the starter trigger wire with the key in the start position. (if you have both, likely starter has failed,) if power only at main terminal, re-check relay, and also test neutral safety switch and ignition switch.If no power at main terminal go back to the battery and re-test everything between again.
Nov 25, 2009 | 2000 Jeep Grand Cherokee
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Logo
52 people viewed this question
Top Delta Woodworking Saws Experts
Frank Mangiapane
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a Delta Woodworking Saw Expert? Answer questions, earn points and help others
