Question about Magellan RoadMate 300 GPS Receiver
Gps is stuck on one address. no matter what address i request
Screen appears to be frozen on this one address.
I need to reprogram my tom-tom one and change who it belongs to as well as the address.
On the map display touch the screen once
Look for the spanner / wrench icon and touch that once.
Kepp using the Right arrow until you see RESET FACTORY SETTINGS
Touch YES.
That should make it as you bought it.
Sep 24, 2009 | Tomtom ONE 3rd Edition GPS
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Sep 15, 2009 | Nextar X3-02 GPS Receiver
Start Up acreen frozen after completed the bar.
if you haven't updated it yet, try the update..it can be found here
Jun 24, 2009 | Magellan Maestro 4040 GPS Receiver
Unit has frozen on one locale
"no matter how many times i try to enter a new location, the screen comes up lorton virginia"
Why don't you try to enter lorton. virginia and see if the screen comes up with Beijing, China.
Apr 02, 2009 | Magellan Roadmate 760 GPS Receiver
Garmin 360 keypad stuck
operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
Aug 20, 2008 | Garmin nuvi 350 GPS Receiver
Screen frozen
It appears that the touch screen isn't working any more. If it is still under warranty then request a RMA from Garmin and send it back.
May 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
May 15, 2008 | Navman iCN 550 GPS Receiver
Its frozen how do you unfreeze ir?
I have a whistler 550 and does not matter what...still frozen
Mar 06, 2008 | Whistler WGPX-550 GPS Receiver
Magellan RoadMate 300 GPS Receiver Logo
29 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
