Question about Sharp CD-DD4500 System
Sharp cd players
Serial number 107 33984 its stuck in sleep mode with no remote
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My Sharp Copier AR153E serial 2506071X was recently serviced. Drum & developer replaced and general maintenace. Now the lights are still on. Advised i need to RESET the Counter. No instructions in...
first you go into dignostic mode by pressing # interput,* interput then machin will go into sleep mode automaticly
then press 20 start 1 start agin start
then turn off machine
again go into dignostic mode
then press 41 start 1 start again start
will go all your advise code
enjoy
ok
Mar 26, 2010 | Sharp Office Equipment & Supplies
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
CD player does not play any CD
not play any cd...........
you can clean the lence or change if necessory,,,
the remot prob.......
you can check battery,,,pad (rubber) or sensor
check and change if applicable ........
or you can also change the remote .......
Jul 02, 2009 | Audio Players & Recorders
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Sharp cd-dp2400 suitable remote contols
i have a sharp cd player and the speakers hook up to the cd player and they light up but when i plug in the speakers to play they wont play what should i do
Sep 03, 2008 | Audio Players & Recorders
Sleep mode
turn off the timer, it should have a button on the remote for that.
Aug 30, 2008 | Panasonic SC-AK24 CD Shelf System
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Sharp CD-DD4500 System Logo
18 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
