Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D
Install ethernet wireless in pci slot
I'm installing a wireless network into my desktop. I've installed the software and am now supposed to insert something into the pci slot. I thought I knew where this was, but when I removed the cover from my cpu (as suggested) it doesn't look like there is anything inside to connect to. Do I just insert into the pci slot and it works?
Yes you should have a few white color slots in there and the card will just slide into the slot. There is nothting on the inside to connect to other than teh slot.
Posted on Jan 02, 2009
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
Tip
How to setup a Wireless Network
1. <b>Connect Your Wireless Router</b> <br /><b>a.</b> Power off your cable modem and your wired PC.<br /><b>b.</b> Unplug the Ethernet cable from your cable/DSL modem and plug it into one of the LAN ports on the back of the wireless router. Leave other end of the cable connected to your PC.<br /><b>c.</b> Connect another Ethernet cable between your modem's Ethernet port and the wireless router's WAN port. (The WAN port should be separate from the other grouped LAN ports.)<br /><b>d.</b> Power on the modem and watch for the status lights to indicate that it's connected to your Internet service. This may take a minute or so.<br /><b>e.</b> Plug in the router. The status lights will blink as it runs through its diagnostics; this may also take a minute or so.<br /><b>f.</b> Start up your wired PC.<br />2. <b>Configure your Wireless Router</b><br /><b>a.</b> Refer to the router's quick-start guide, launch Internet Explorer, and type in the address indicated in the guide.<br /><b>b.</b> Follow the on-screen setup wizard, which will guide you through the process step by step.<br /><b>c.</b> Enable your router's security functions. This is very important if you don't want other people attaching to your wireless signal. The options will be WEP and WPA. Both will ask you to enter a key. Depending on the router's manufacturer, you may have to go into Advanced Settings to accomplish this step.<br /><b>d.</b> Change the default administrator's password, Almost all hackers know them.<br /><b>e.</b> Change the SSID-the name of your wireless network. Again, hackers know many of the default SSIDs and can use them to hack your network.<br />3. <b>Install a Wireless PCI Card in a Desktop PC</b> <br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Remove the cover.<br /><b>d.</b> Find an available PCI slot and remove the slot cover from the back of the PC.<br /><b>e.</b> Carefully insert the antenna through the open slot in the back of the PC, carefully push the card in the slot, and secure it. Replace the cover. <br /><b>f.</b> Start up the PC. It should recognize and install the new PCI card.<br /><b>g.</b> Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router.<br />4. <b>Install a Wireless PC Card in a Notebook PC</b> <br />Many notebooks have built-in wireless cards. However, If yours doesn't, you can install either a USB wireless adapter or a wireless PC card just follow these instructions.<br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Plug your USB wireless Adapter or wireless PC Card into an available slot on the side of your notebook.<br /><b>d</b>. Start up the PC. It should recognize and install the new PCI card.<br /><b>e</b>. Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router. well, thats pretty much it. Hope this is helpful to all you home networkers.<br />
on Jul 11, 2011 | Computers & Internet
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
Pleas help, I need software on : Olicom OCE4XODI Ethernet PCI/II 10/100 MLID v1.08 (970130)
Hello k_kmail,
I've given you a "Link" to the Website, where you can
"Download the Software / Drivers," you need.
If you look at the list of {Items}!
You will see the NETWARE/NW4X/OCE4XODI.LAN
for the [Ethernet PCI/ll].
Click on the "File: oc218x-3.exe"
This will download the Drivers!
"Install the Drivers and restart the computer!"
This will "Update the software."
"Best Regards"
Click here for Software: http://www.network-drivers.com/drivers/27/27565.htm
Jul 23, 2011 | Olicom Ethernet PCI/II OC-2183 Network...
I have 2 DFE-528TX PCI Adapter but I dont know how to install on my PC. On my PC there are 2 PCI slots. Please help me to solve my problem. Thanks.
These are Ethernet adapters for networking, they simply plug into ANY PCI slot, and then you must install the Drivers, and any software that comes with them... than they can be used.. You would NOT usually install TWO unless you had some special purpose..Like spanning different networks etc All about card below.
developer.novell.com/yes/70609.htm Drivers below. www.howtodrivers.com/model6633.html
Mar 07, 2010 | Computers & Internet
Ethernet port not recognized
try re-install all drivers and start with the chipset driver.
May 09, 2009 | E-Machines eMachines Desktop PC
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
No ethernet port on older Dell desktop
Yes, all you need is a PCI ethernet card. You can pick them up rather cheap. Here is one. You basically plug it into an available PCI port on the inside of your computer. If XP doesn't automatically install it, just insert the included CD with the drivers on it and XP will do the rest. And remember to please give this answer a good rating of fixya. Thanks.
Dec 26, 2008 | Dell Dimension 2400 PC Desktop
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
I have an Acer T135. I want to install a Linksys Wireless-G PCI Adapter. I believe I have to remove the factory installed Ethernet card. If true, where exactly is the Ethernet card, what does it look...
You dont have to remove the ethernet card, as i suspect it would be buit onto the motherboard in anycase. Just install the wireless card into a free pci slot.
Jun 21, 2008 | Acer Computers & Internet
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
