Question about Microsoft Wireless Racing Wheel for Xbox 360
Steering wheel makes a complete 360 deg
The wheel goes in a circle. turned wheel off then on and it calibrated upside down
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
Atan
Make sure you've set the proper angular mode. The 50g offers three choices: RAD (2pi for a complete circle), DEG (360 for a circle) and GRAD (400).
If you're certain you've got the right mode, please post an example of a wrong answer.
Apr 02, 2014 | HP 50g Graphic Calculator
I have a 1999 Pontiac grand prix gt..my problem is that the steering wheel almost does a complete 360 and when I make a left turn it makes a tinking sound( I guess that's the best way to put it) just...
what do you mean by 360 all steering wheels do this can you find another way of describing this, does the steering colum feel lose from left to right when you try to move it?
Jun 13, 2012 | Cars & Trucks
Steering wheel turns/spins 360 degrees
If Your steering wheel keeps turning as in a 360 degree circle that means the steering column has broken or came away from the steering rack they are usually connected by what you call steering ujs something on shaft from column to rack has broken away nothing to do with cv joints or brake fluid if it was belt related that has snapped the steering will still turn it will be just really heavy the pump just helps assist steering my money is on the steering column shaft
Apr 06, 2012 | 2000 Honda Passport
How to explain one sixth turn of an object
Imagine you are looking at a wheel from the top. There is a notch on that wheel. When you turn the wheel, the notch will move along the circular path of that wheel. When the notch moves completely in one whole turn, it has moved 360 degrees. Remember there are 360 degrees in a circle.
When the notch moves only around half of the circle, it has moved only 180 degrees. The notch should be on the opposite side it started on.
One 1/6 of a turn will be equal to 1/6 of 360 or 60 degrees. So the notch will have only moved 60 degrees if you turn the wheel 1/6.
Nov 11, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
93 Jeep Cherokee - steering problems
Check both front wheels with the steering wheel centered. One or both may appear to be pointing in the wrong direction slightly. Check both sleeves on the tie rod ends to make sure they are tight and not able to turn. (adjustment sleeves are slightly different than on most cars. One sleeve extends from the drivers side across the front and is about 21/2' long the other is shorter and is about 5" to the passenger side of the pitman arm on the steering box. If either moves, turn it 'till the wheels are fairly straight, tighten the bolts that are on the clamp around the slotted tube, and bring it to an alignment shop and have the toe in re-set.
A condition such as this is nothing to mess with. loss of steering is extremely dangerous.
Apr 18, 2009 | 1993 Jeep Grand Cherokee
Steering Wheel is upside down
You can problably take the wheel off and turn it around. The shaft and wheel are splined. You will need a special puller. Most auto parts stores have tool loaning programs. Just ask for a steering wheel puller.It is a fairly easy job. About a three out of five.
Dec 02, 2008 | 2005 Chrysler PT Cruiser
Microsoft Wireless Racing Wheel for Xbox 360 Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
