Question about Makita BMR100 Radio
I have the e problem but i have tried all of your solutions what could i try next? thanks
The E comes up when i try to turn on my radio but i have tried all of the solutions.i tried the backup battery's and the dc connector but no luck.do you have any more solutions.thanks
    New Friend:
Do you have the solution yet? I have the same problems
Posted on Nov 12, 2012
I have midland wr-100 weather radio. radio is programed with right codes and channel numbers all i get is a high pitch tone coming out of the speaker
Good morning, afternoon, evening or night; whatever time you're reading this. Thank you for choosing FixYa to assist you with your problem. The problem is that you are hearing a high pitch tone coming from the speaker. First check to make sure the weather mode is on. To do this, switch the radio to the right side and make sure the Weather Radio On/Off switch is switched to On. You should also check the alarm to make sure it's not on and set. If the alarm is on, turn it off. Your alert type may also be a cause for this. If your alert type is set on TONE, try changing it to DISPLAY or VOICE. Reply back if you still receive problems. Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a nice day, evening or night; whatever time you are viewing this. Hope this helps and remember our site the next time you need troubleshooting assistance.
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Did the battery reconnect on 1996 maxima radio turned on then wouldent turn on the next time the car started did the reconnect again and it didnt work checked all fuses is there any thing else?
Thanks for using FixYa and welcome to the site. I would say the radio is locked. You are going to need a radio code to unlock the radio. It may be in your owner manual. If not, you can try this website to get your code. Thanks for using FixYa and have a good day.
www.radio-codes.com
Apr 01, 2011 | 1996 Nissan Maxima
Trying to set up midland wr-100 weather radio in Cass county Michigan but don't have the instructions for the radio.
Good morning, afternoon, evening or night; whatever time you are viewing this. Thank you for choosing FixYa as your one-stop spot for finding solutions to your problems and thank you for reading my post. So you are saying that you're trying to program the information for Cass County, Michigan, but don't have the instructions for the radio. Well you have come to the right place to find an answer. Not am I going to give you the URL address for downloading the manual, but I'd also like to give you the URL address for the information you will need to program into your radio. Here is the URL address for the manual - http://www.midlandradio.com/Resource_/OwnerManual/122/WR-100B.pdf. Here is the URL address for the programming information you need for your state - http://www.weather.gov/nwr/CntyCov/nwrMI.htm. Your county has four transmitter locations and three frequency channels. Choose the transmitter location and frequency channel that is nearest to where you live. If you follow this solution correctly, your weather radio should be ready to go. Hope this solution helps and thank you once again for choosing FixYa as your one-stop solution spot for all of your problems. Make sure you visit us again when a problem occurs. Have a good morning, afternoon, evening or night; whatever time you are reading this.
Mar 30, 2011 | Midland Weather/Hazard Radio with SAME...
I have a digitech uhf 2 way radio and not sure how to turn it on. Tried all the buttons and the radio is fully charged. thanks
Hold the power button down for a few seconds until it turns on. The power button has a symbol that looks like a circle with a line in the middle.
Dec 03, 2010 | Radio Communications
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Code for radio/cdplayer 6000 CDRDS Ford Focus
Remove the radio from the dashboard and quote the SERIAL NUMBER....normally begins with M * * * * * *
Apr 24, 2009 | 2001 Ford Focus
My 1997 Honda Accord LX 4 door wont start. The car was running fine the night before.The next morning I tried to start it, and it wont even crank. The battery is good, I checked it out. All the lights and...
Hi
Try to jump start the car.
Put the jump leads on and leave it for 10 mins
that will charge the battery up
then try and start.
Also check the starter motor.
Jul 17, 2017 | 1997 Honda Accord
Sansa fuze radio will not work red speaker showing
I had the same problem and I found a solution. Turn your mp3 player off and place it face down on a hard surface. place down on the back of the mp3 where the function buttons are and press down firmly. I believe this unlocks the radio. Turn the mp3 player back on and go to the radio. The volume should work now.
Jan 05, 2009 | Audio Players & Recorders
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Makita BMR100 Radio Logo
376 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
