My digivox is scrambling all my channels. Was working fine for about 6 months, then all of a sudden all channels gone. tried entering 0000 again. But nothing!!!! Can anyone help
    Sergeant:
  • 184 Answers
Are ur fta channels still working if they are then ur cable co. has changed codes you'll need to put new codes in or download new software to fix this problem hope that helps.
Posted on Jan 03, 2009
Digivox t keeps rebooting every couple of mins. Whats the problem . Channels all work fine when its on but constantly going of and coming back. Looks like it freezing just before this happens. Also have...
i think that the problem may be that you are constantly putting in codes and have not downloaded the latest firmware on it this sometimes happens /as for your other box sorry it could be a 100 things
May 10, 2010 | StarTech.com StarView SV211K 2-port KVM...
My digivox has lost nearly all channels apart from freeview options nd sky sports 1-4. All movies nd espn gone. I've tried rebooting box,checked emu1004 nd changed frequencys back nd fourth but now back to...
if its a cable box then sorry there is no fix for this problem yet if it is a terrestrial box then delete the scrambled channels and rescan if you factory reset the box then you must install the latest firmware
Apr 26, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Some channels are not working, says scrambled or bad channel
hi pinkzz you must delete the channels that are bad/scrambled before you rescan because the box allready sees that the channel allready exists
Apr 21, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Telewest codes for digivox 17/08/2009
AA B7 D1 D9 CE 8E 83 AF
8E 80 D7 EF 44 93 02 2B
Aug 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Digivox xl telewest
5a 01
00 aa b7 d1 dg ce 8e 83 af
01 8e 80 d7 ef 44 93 02 2b
Jun 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
Scrambled channels
ok mate ur not gonna get dem all bak on but ill be able to help ya get sum bak on ok well first type dese numbers in 00= bo b8 4f 04 e6 5f 87 80 and that shud give ya all tha channels ecept for movies and sky sports aswell
Apr 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview3 super, 3 or 4 Irish channels only, emu switched on.
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Feb 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
Disney Channels Gone
MAKE SURE YOUR KEY EMU IS ON.
MAIN MENU
SYSTEM INFORMATION
ENTER YOUR 4 DIGIT CODE (1OO4)DIGIVOX,I THINK ITS 1571 FOR STARVIEW.
ARROWN DOWN TO KEY EMU AND ARROW ACROSS TO ON.THEN EXIT AND THAT SHOULD BE IT.
Dec 22, 2008 | StarTech.com StarView SV211K 2-port KVM...
Digivox DV3 cable box
You need to Enable the Emulator as this is what clears scrambled channels. Main Menu -Factory Settings enter code 1570 which should give you a new CAS menu. Go down to EMU and switch it on with >vol key. Go up to Negravision and select your area providerer and press OK. Exit and scroll down to Default and hit OK. Will flash "Saving". Exit all the way out.
With certain channels when you first switch to them they may take a minute to upload data automatically.
Good Luck.. Tom (Dublin)
If unsuccessful it is because the code above does not work on your Box. You will know straight away when you enter it if the CAS menu doesnt appear
Jul 08, 2008 | Televison & Video
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
