Question about Symantec Procomm Plus 4.8 for PC
My line is connecting,I get the Modem sounds but no answer,then I get redial
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Network drivers are not worke propely
Instructions
    • 1 Check which communication port and interrupt your modem is set to use. Typically, these are hard-wired selections on the board itself. Changing the jumpers on the board changes the port address and interrupt number. You must give forethought to the consequences of the decision. There are only two interrupt lines usable and four port addresses that are possible. Only one port can utilize an interrupt number at a time.
    • 2 Change the port and interrupt assignment if required. Restart your system and see if this solves the problems. If not, find the documentation for your modem. You must now generate the proper initialization string for your modem to maximize your communications. Some of the settings in the initialization string determine the audible sound of the modem when dialing and connecting. More important settings have to do with number of rings to wait before hanging up, time to wait between redials, sensitivity of the modem to line noise and enabling or disabling the transfer mode of X2 or V.90 (the two formats for 56K communication).
    • 3 Find the modem driver that you are using and check that it is the correct driver. There are many drivers available based on manufacturer and model of the modem. Not only is the driver modem specific but also the recommended initialization string. Make sure your modem receives the correct initialization string in the setup file or preference window in the application that uses the modem.
May 13, 2011 | HP Pavillion DV6227 Notebook
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
Device manager says
reinstall original driver for this modem
Nov 07, 2009 | Dell (7386R) Modem
Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
Sep 14, 2009 | Panasonic Lands Phones
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Modem not Working
This error cause:
  1. Incorrect Windows connection settings.
  2. An incorrectly configured modem.
  3. A corrupt dialer.
  4. Out of date modem firmware.
But before trying anything chech your modem is ok and driver is installed correctly.
Click here, there is a detail help how to fix your problem.
Please post your feed-back.
Thanks
Iqbal
Apr 29, 2008 | Acer Aspire 5100 Notebook
Nokia 5200 Modem Is not responding
first of alll go to device manger in pc and then go to modems section there u can find ur phone modem listed there . then right click ur phone modem and select properties then go to advanced tab . there u can find a column named as extra initialization commands if something is wrtten inside that column delete it and select ok . then clear cache of ur cell phone . restart ur phone and pc and try
Nov 11, 2007 | Nokia 5200 Cellular Phone
Sending and receiving problems
Where the telephone line comes in from the wall, make sure that it is plugged in the "line" or "wall" port. There is probably another port call "tel" or "acc". If the line is plugged into that port you will still get a dial tone but you are not connected to the fax's modem. You hope that's it. Ed
May 15, 2007 | Canon FaxPhone L75 Plain Paper Laser
Symantec Procomm Plus 4.8 for PC Logo
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
