Question about Honeywell Programmable Thermostat Heater
Turned switch to heat but programmable still reads cool
  • 499 Answers
Get a new stat.
Posted on Oct 31, 2012
RTHL2510 thermostat will not turn on blower fan in heating mode. cooling mode is perfect.
did you set new stat for the type of heat you have ??? maybe necessary to set dip switches or program settings to match time of heat.
Oct 27, 2013 | Honeywell Focus 6300B 5-2 Days...
Tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 | Heating & Cooling
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
I changed the batteries in the digital thermostat but the heat won't come on. we woke up and the batteries were dead so we replaced them. we have checked the breaker and the switches on the unit but no...
Turn the system off,at the breakers,and turn the thermostat off.Leave it for 15 minutes,then turn the breakers on,and set the thermostat,and wait to see if it resets,and come s on.
Jan 17, 2010 | Honeywell Electronic Programmable...
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
Hi there.....I am REALLY hoping you can help me. We have a Honeywell automatic thermostat. Every year when we switch from heat to cool.....we cannot get cool air. Instead, it is getting hotter in here. I...
if you have to switch from heat to cool, then tou don't have an automatic thermostat ---- you have a programmable heat and cool thermostat. For cooling mode you have to program in the temperatures you want for the various times of the day and days of the week. If you have a fan selector for auto or on, switch to on and see if the fan works. Let me know the results.
Jun 24, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
27 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
