Hoover hnl7146 wont empty
About 2 weeks ago my machine stopped emptying during cycle, it would stop and still be full of water,up until yesterday we could manually drain the machine so it was ok then that stopped working as well and i got the start/delay start flashing 3 times which pointed to a pump failure i removed everything and cleaned and still had the same problem so i replaced the pump today and its still the same.when i put it on to drain i get the click but nothing at all happens after a few minutes i get the 3 flashes again. any ideas what i can do?
    Top Expert:
  • Washing Mach... Master
  • 42,176 Answers
Program board possible failed
call a technician to have a proper diagnosis done to save guess money
Posted on May 07, 2017
5 Suggested Answers
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
SOURCE: Hi my Hoover Nextra 6
the lights indicated a blockade, remove the front panel at the bottom to reveal a drain plug, the blockage is most likely at the back of the drain plug as the drain motor impeler sits directly behind the plug.
Posted on Feb 20, 2011
Hoover NHL 642 won't empty r spin
check that the drain hose pipe/pipework is not blocked, if it is the machine will automatically stop
Nov 08, 2013 | Hoover Washing Machines
Jan 16, 2010 | Hoover Washing Machines
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Washer filled up for the rinse cycle then stopped won't do anything now. checked the outlet and have power there. Washer still full of water.
first of all you need to empty this washer by pulling the drainage pipe out of the waste pipe at the back then place a bowl on the floor and place the pipe into the bowl until all the water stops,when bowl gets to full then lift pipe higher than the washer to stop water coming out,once empty renew the carbon bushes on the motor as this will be the problem.
Jul 06, 2009 | Washing Machines
Washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
Jun 16, 2009 | Hoover Washing Machines
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Our Hoover HD98E Dishwasher stopped working properly today. After a while the machine stops during the power spray cycle and just buzzes as though the pump is powered but not spraying. Is this the pressure...
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
Mar 14, 2009 | Hoover 24 in. DT999 Free-Standing...
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
