Question about Wesco Star Wars R2D2 Projection Alarm Clock
Instructions for original wesco r2-d2 alarm clock
Its not the projector one ots the original one that projects a picture of aninka
Change time zones
Hold down the + button on front of unit until the time zone moves.Then let go when it reaches the correct time zone.
Jan 26, 2014 | Hammacher Schlemmer The R2-D2 Projection...
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
R2 won't move forward on command
Have you checked to make sure his wheels are unlocked? Page 4 of the manual shows you where it is. http://www.hasbro.com/common/instruct/SW_R2-D2_Interactive_Droid.pdf
Feb 17, 2013 | Hasbro Star Wars R2 D2 Interactive...
Instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Oct 23, 2009 | Audio Players & Recorders
Interactive r2 d2 gets stuck
There could be something blocking the drive gears to the treaded wheels making making the robot go backwards.
Apr 28, 2009 | Hasbro Star Wars R2 D2 Interactive...
Alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Jan 09, 2009 | Emerson Smartset Clock Radio
Wesco Star Wars R2D2 Projection Alarm Clock Logo
67 people viewed this question
Top Wesco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Wesco Lands Phone Expert? Answer questions, earn points and help others
