Question about HP Photosmart Pro B9180 InkJet Printer
Hp photosmart pro b9180 prints orange instead of yellow
Printer not printing yellow comes out orange
  • 18 Answers
SOURCE: HP Laserjet printer not printing
may be some paper stack in the fuser unit.try to clear the stack paper from fuser unit.
Posted on Feb 20, 2008
SOURCE: Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Posted on Sep 05, 2008
worldvet
  • 859 Answers
SOURCE: hp 3310 photosmart only prints in yellow
On the left side of the print head carriage is a white plastic gear that drives the ink pump. Check it first to see if its firmly in place, has chipped or worn off teeth or looks damaged in some other way.
If this white gear driving the ink pump is damaged or looks odd let me know right away so we can address this issue.
Now, there is a trick for resetting your particular HP printer. This sounds and is convoluted but it will work. However, the system will think all your ink cartridges are full. If they are rather full okay. If they are near empty you will want to run this hack again as the ink nears low. You won't get a ink low warning correctly after this until you've installed new full tanks eventually.
Turn the printer on. At the same time, using your left hand, press the OK, Cancel, Black, and Color buttons down and hold them down. While holding these down buttons use your other hand to turn the printer off, still holding the four buttons down with the left hand. Once the printer has powered down fully you can release the buttons. Now, the printer will initialize and then run a maintenance check. If you printer is otherwise okay, no damaged circuitry or gearing you will be fine. Turn the printer on. It will start up and shut itself off, this is expected. Once it is off again, turn it back on once more and this time the printer will run the maintenance routine. Have paper in the feed tray.
1.) Check left side of printer carriage for the white gear that drives the ink pump. Look to see if the gear is off, broken has worn or chipped teeth.
2.) Turn the Printer On.
3.) Hold down the OK, Cancel, Black, and Color buttons with your left hand and hold them down.
4.) Use your other hand to turn the printer off. Keep your left hand on the buttons until the printer is off.
5.) Turn the printer on, wait for it to turn itself off. Have paper in the feed tray.
6.) Turn it on again and it will enter the maintenance mode. Follow any prompts during the maintenance mode, if any.
You should be back in business now. If not, try the routine again, sometimes you have to run it more than once. Should it still fail, let me know as you may get an error message and error number.
Use the Comment Text Entry Box below to comment back with any other questions or point out failures in this hack.
Regards,
Worldvet
Posted on Nov 20, 2008
  • 990 Answers
SOURCE: hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Posted on Jan 12, 2009
Chitownbarb
  • 21 Answers
SOURCE: installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
Posted on Jun 29, 2009
My printer will not print in yellow or orange, just print black pink and purple?
Try a hard reboot. Unplug the connections between the computer and the printer (power cord first), wait 10 mins. then plug it back in, other than that you can try uninstalling the printer and do a fresh install. If still a problem, try updating the drivers and op system for the printer.
Aug 20, 2014 | DELL2155CN 2155cn Multifunction Colour...
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Printing only orange and yellow
Hi Florian,
if the cartridges are full, but still not all colours appear, it could be a driver issue. Try uninstalling the printer, reboot and install it again. Even pull the cartridges out and back in, just to be sure. Preferably check for newer printer drivers on Canon´s website. Let me know how it ended up Flo, ok?
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is not printing anything orange, it comes out pink. Just put in new cartridges.
It sounds like your yellow is not printing correctly (probably a clogged nozzle). If your printer has separate cartridges, replace the yellow. If you are using aftermarket cartridges, you should try using OEM cartridges since they are spec'd to the printer. If you are usng aftermarket or reloaded cartridges, the ink may not be up to specs. In any case the yellow ink cartridge needs to be replaced. Make sure to run a deep cleaning and alignment after replacing the cartridge.
Sep 11, 2009 | HP Computers & Internet
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
Orange/Yellow tint to pictures
I'm afraid I don't have a solution - I have the same exact problem with my Canon MX860. Did you ever get a solution?
Jul 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
OKI C5800 color problems
Open the top cover. using a clean soft paper towel clean each othe glass vanes that hang down between the drums that are attached to the top cover. I use Alcohol, and a different paper towel for each vane.
Oct 25, 2008 | OKI C5800Ldn Led Printer
HP Photosmart Pro B9180 InkJet Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
