Question about Yamaha Aw4416 Aw 4416 Workstation
Aw4416 unit will not boot up completely
Can somebody post the PA800 Diagnostic Menu Command
The details are highly confidential and have only ever been released to engineers under Non Disclosure Agreements, who work closely with Korg in the design process. If anyone tries to tell people about it on the forum then a breach of an NDA has occurred and whoever did it could be sued by Korg. The person posting those details could have their account on the forum suspended.
Please understand that there are very good reasons why Korg want to keep those details confidential. The functions were designed for use in the factory when the keyboards are manufactured. Two of the functions can completely wipe the internal SSD and the boot EPROM rendering the complete keyboard unusable. One of the circuit boards would have to be returned to a factory for the chips to be re-initialized using specialist hardware plugged directly into the CPU board. The necessary hardware to re-initialize the SSD and Boot EPROM is not even available to Korg service centers.
If you are someone who has discovered the way to access the system diagnostic menus, then there is a high risk you will completely trash your Pa2x/ Pa800 etc, turning it into a "brick" that will no longer be capable of reloading the OS or factory data. Korg representatives have said to us several times that damage caused in this way is NOT covered by warranty. If two of the functions in the system diagnostics menus are used, then to get the keyboard working again, service centers will have to replace the complete "main board". This is the board which contains the SSD and boot ROM chips. You are looking at a repair cost of over $800 plus shipping.
Oct 24, 2014 | Korg Pa800 Synthesizer
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Sep 30, 2013 | Yamaha PSR-E413 Portable Keyboard
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
Just bought. New b205d power is on but no sound
These are a nice unit... just bought three of them that were dead... I have repaired one so far. I assume you mean the blue LED is on indicating power is on. What I want you to test is if injecting signal on the BACK of the unit jack (power amp in) will create sound. If it won't then better exercise your warranty. The one unit I have completed repair had a bad 15 volt regulator in it... the second that is almost fixed somebody had blasted the input circuits... probably connected to a speaker output... don't do it... these are LINE and MIC level units. If you need to tap off a speaker output, use a DI box with the unit. The third unit I have not received yet. Drummer used the repaired one as monitor last night and was impressed with the power this unit has.
Jul 22, 2011 | Behringer Eurolive B205D Active 150-Watt...
Power comes on but the psr 9000 yamaha does not boot up past the first page
The unit probably is detecting an error during the power on test... A long shot MIGHT be a button or key that is stuck on, that is sensed as being pressed. See if all the buttons are completly up. If the unit has a harddrive, a failure of it can block the booting even though the operating software is not on the drive in these. If you find a button that is sticking, put a tiney bit of CRC226 around it with a Q tip. You can get the CRC226 in the electrical dept of Home Depot. You just want to wipe the edges of the button to lube it a bit.
Apr 11, 2011 | Yamaha PSR-E413 Portable Keyboard
Cannot Boot!! Not dtect HDD correctly, Please Poer Off, and check H/W .... this i sthe message that appears on my Tascam2488mkII everytime I boot it up... can someone please help
It sounds like you have either a hard drive failure or have lost the internal operating system in your unit.
BE VERY careful if you have critical data as it still might be recoverable.
I would contact the factory on this one.
May 19, 2010 | Tascam 2488mkii 24 Track Recording...
Numark Dmc2 issue
It is shutting down the DMC completely as in power? Not completely familar with this unit,but do use numark equipment. Is the software control compatible with your pc? As in 32 or 64 bit . May be a safty shutoff to keep from corrupting you software
Mar 05, 2010 | Numark Dmc2 Rackmount DJ Software...
Yamaha Aw4416 Aw 4416 Workstation Logo
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
