Question about GE Dishwashers
Dishwasher has no power
No power no sound nothing just stopped working after cycle complete
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
aborcass
  • 2651 Answers
SOURCE: no power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Posted on Feb 23, 2008
rickzilla
  • 706 Answers
SOURCE: power outtage blues
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Posted on Dec 13, 2008
SOURCE: dishwasher does not complete the cycle
Repair guy came out and after an hour of taking things to bits and not finding a leak , we managed to identify the problem as originating from a faulty door seal at the top door lock ( it was ever so slightly dented in/warped) which had caused the water to track through the door lock down into the machine and trip the electrics after 30 minutes in the cycle. He'd never heard of this happening before - just my luck!!
Door seal replaced and ( so far) everything working fine.
Posted on May 11, 2009
  • 30 Answers
SOURCE: Normal cycle never completes. Have to CANCEL to
check the temperature is reached the setting temperature,
or replaced the control board
Posted on Jun 04, 2010
We lost power for 2 days and when the power returned our Asko D5253 dishwasher began making noises as if it is trying to drain. It was not on when the power went out. We tried turning it on and off
Yes, it is stuck in "drain mode" just let it complete the cycle and it will turn off. It may sound like it is on for a long time, but just be patient.
Best regards,
Bill
Oct 24, 2014 | Asko Dishwashers
Dishwasher will not go thru full cycle
Hello friend, thank you for your post!
Based off the information you provided your Frigidaire dishwasher will not complete a full cycle. It sounds like it could be an issue with the control panel or door switch. When your dishwasher stops working does it display an error code or do a series of lights flash? I would recommend performing a reset on your appliance which can be done by disconnecting power from your dishwasher by either unplugging it or flipping the household circuit breaker. Hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire Dishwashers
Kitchenaid dishwasher cycle not complete
is there enough water pressure some times the cycles wont operate without other things working?
Sep 08, 2017 | Dishwashers
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
