I had to purchase a new computer and now need the drivers to connect my MFX-1430. What can I do.
  • Jessetech May 11, 2010
    go to the manufacturers site
  • john vecchione May 11, 2010
    what kind of copier?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Goto muratec.com , go to support, drivers. IF you did not know, Muratec is the maker of your device. Make sure you find the right drivers for your machine !!!! PAY CLOSE ATTENTION!!!! look for versions and etc...(x64) or (x86) it depends on your OS (operating system).
Posted on Jan 04, 2009
How select bypass tray
There are two ways to select the bypass.
One way is from the pc...
This involves selecting to print and then in preferences picking the bypass.
The other method of selecting the bypass is from the copier.
To select the bypass for copying press bypass, press others, press bypass, select paper type and press enter.
MFX 1430 SUPPLIES
Sep 13, 2012 | Muratec MFX-1430 Copier
Can you adjust the edge erase area around the border of the copies printed out on the MFX 1430. I would like to reduce it,because it cuts off some of the letters and numbers
Unless someone has changed it(made it larger)...factory default is 2mm void at the edges and you can't make it any smaller than that.
Nov 28, 2010 | Muratec MFX-1430 Copier
Printing problem
You cannot use the "add-printer" wizard to install the 1430...unless you got the machine with the PCL Print option installed; the unit comes standard with only GDI printing.
For the GDI printer port to be created on your PC you must install the machine using the installation disc provided with the machine.
Jul 27, 2010 | Muratec MFX-1430 Copier
Muratec MFX 1430 Fax / Printer / fax does nto turn on.
UNFORTUNATELY YOU MAY HAVE LOST A PCB. IF THERE IS NO DISPLAY AT ALL YOU WILL PROBABLY NEED A SERVICEMAN. WOULD STRONGLY SUGGEST YOU GET EQUIPEMENT LIKE THIS ON A "SURGE-PROTECTOR". ITS A LOT EASIER TO REPLACE A $25 SURGE PROTECTOR THAT POSSIBLY HUNDREDS FOR A NEW PCB.
Jul 08, 2010 | Muratec Copier
I need a lid hinge the number on the side is 07do4l do you know where i can get this part
The lid hinge on the mfx-1430 which "tends" to be the one that breaks is part #Z906461000 which is the hinge on the L.H.S. as you are looking at the machine from the front. Contact any copier dealer locally who deals with Muratec and they should be able to provide the part.
Feb 10, 2010 | Muratec MFX-1430 Copier
Where can i find document rollers for document feeder?
document rollers is located immediately beside entering the paper or on paper if you use presenting with pallet
Oct 08, 2009 | Muratec MFX-1430 Copier
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
My computer does not detect MFX 1430 printer. I think I need the usb driver for the usb cable.
Yes you will need drivers to run a "Local" set-up which is what a usb connection is called. Install drivers BEFORE connecting usb cable. You can download drivers from Muratecs web site www.muratec.com
Jun 30, 2009 | Muratec MFX-1430 Copier
Muretec mfx 1430 streaking through the adf and its not the **** glass. Off the glass looks fine have swamped out the whole feeder twice same problem.
Hello sir; Let's try two things , 1st, make a copy go through by ADF. 2nd, make another copy direct from the glass. if 1st one coming out with streak line that's mean on the left hand side of the plateform have a piece long strip glass need to clean.
if streak line coming out from 2nd copy that's mean you need to replace drum cleaning blade.
Mar 13, 2009 | Muratec MFX-1430 Copier
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
jasbo
jasbo
