Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
No power to GE dishwasher
No lights no sounds
The start light is not coming up
washer has high pitching sound with no power setting lights on
May 10, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
My GE Profile dishwasher won't start. The power
More then likely the Control Panel has faulted and will need to be replaced. You can try shutting off power for a few minutes and see if it resets.If so great if not time to replace.Not that hard of a repair for a DIY
Jan 08, 2018 | GE 24 in. Profile PDW7800 Built-in...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Jun 02, 2009 | GE 24 in. PDW8800J Built-In Dishwasher
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
GE ZBD6880KOOSS
This is an unusual failure. The humming could be a motor (or valve) that has power but isn't moving. But that doesn't explain the (absence of) lights on the control panel. I suggest you call a professional.
Mar 31, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
