Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My whirlpool side by side
Yes it make a slighty noise when i i press the despenser also i check in the back and is not clog you could see the waterrunning threw but you can''T get water from the despenser
  • 242 Answers
If you can see the water running through the line when pressing the button in the door it must be going out somewhere inside or under the unit. If this is correct your plastic water line needs repaired.
let me know what you find.
Phil
Posted on Jan 03, 2009
Water dispenser does not work. However, the ice maker does work so there is water availabe. Could this be a pump problem, if yes how do I replace.
It is not your pump, because despenser and ice maker both get water from the same pump.
Water despenser is activated by a small plunger when you press your water glass against it
to release the water. This is your problem, bad plunger.
Feb 03, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I have a whirlpool gold gs6nbexrl002 the ice maker works but the motor will not turn to despense ice thru the door i was wondering if there was a wiring schematic so i could check for power to the motor? ...
Yes there is but Whirlpool has become very strict about posting their material. I have to purchase their subscription yearly to have help topics to assist my customers. I will assist you if you like but posting the GS6NBEXRL00 Wiring Diagram here or on-line I cannot do. Let me know through Fixya, my profile or the capsha at top and near bottom of site here, Thanks, Sea Breeze
Jan 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool side by side refrigerator model # ED5VHGXMQ stopped making ice and despensing water. could this be caused by the filter?
Yes, this is a symptom of the water filter in need of replacement, I would recommend starting with filter replacement, if that doesn't solve the problem, then I recommend checking the water supply at the back of the refrigerator. Shut the water valve off that is inline to the refrigerator, disconnect the tubing from the refrigerator at the water valve or the water tube couppler on the back of the refrigerator, have a container available so that you can run about 1 or 2 gallons of water out of the water supply tube in to the container to be able to see if the water pressure seems to be strong and if there is sediment or other foreign matter that needed to be flushed from the system. If water supply seems good then reverse the process to supply water back to the refrigerator. If water supply is not good you need to have a technician or plumber check into the water supply further.
GOOD LUCK !
Aug 04, 2010 | Whirlpool ED5VHGXM Side by Side...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
Apr 10, 2009 | Whirlpool GS6SHEXNL Side by Side...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
Help
make sure the lid is making contact with the switch when the lid is closed, listen closly for a "click" noise upon closing the lid, if you dont hear anythig the lid is no tbeing recognized as closed therefore will not enter a spin mode for safety reasons.somtetimes by pressing down harder on left side of the lid you can get it to startup. if this is the case a simple solution may be in order, after lifting the lid make sure the scrrws attaching the lid to the hinges are tight, then if you place your hand under the left rear side of the lid you feel the lid actuator( its the opposing side to the door hinge) with a nutdiver( or similliar hollow pointed metal object) slide it over the metal hinge and apply force to slighty bend to toward the reare of the machine( as you apply pressure the lid will want to push against you , thast s normal its the hinge your bending) after slighty bending now see if tyou can here the click?
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
