Question about Hartke VX3500 Bass Guitar Combo Amplifier
No sound coming out for my hartke amps?
Power is ok.only no sound coming out ?
    Novelist:
    Champion:
  • 225 Answers
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Posted on Nov 01, 2012
I need a schematic diagram with values of components for a hartke gt100 amp
Request the schematic diagram directly from Hartke.
May 23, 2017 | Hartke Music
Dropped Hartke amp b 600 and now it has no sound
There are too many possible problems for someone to advise you without the amp on the bench. I suggest taking it to an authorized Behringer repair as they will have better access to parts should it be a cracked board.
Jun 06, 2016 | Hartke Music
Ha3500 hartke sound goes off with a click after 5 seconds .what is causing the problem
Sounds like the loudspeaker relay switch is disconnecting the spkr.
i) Check heat sensor on heatsink has good connection to PA board. Dust on h'sink/fan usually needs vacuuming off!
ii) Check voltage on the amplifier output resistor R334 is at 0v (referenced to chassis) - if this voltage is raised,the amp stage is faulty.
Otherwise the fault lies in the speaker protection stage (IC301).
Sep 24, 2013 | Hartke Ha2500 250watt Bass Amplifier Head
I recently bought hartke a100 and it makes a sound quite bigger than normal bass amps does when i switch it on . same thing happens when I swith it off.The sound comes up along with a blue beep on top of...
The amplifier takes a bit of time to come to DC balance and same thing happens as power goes down. Some fancier units will have a relay to disable speaker until balance occurs, but this one does not. As long as the cone centers within a couple seconds it will not cause a long term problem.
Sep 05, 2011 | Hartke A100 Combo Bass Amp
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
This problem has to do with a Hartke 3500 bass amp. I recently purchased a replacement UCISC (the part with the female plug and fuse box) and replaced it. I tried to be very careful putting all of the...
Easiest way to check is to measure the resistance between the ground pin of your cord and the chasis of the unit. It should be very low. That is the only critical one... Look at a receptacle. See one bllade is wide? That is the neutral. The other one is the HOT side. The HOT SIDE should go to either the fuse or the switch first in your unit. If you have those right the third wire will be right.
When powering up an amp there often is a noise until the amplifiers balance out. Very high quality and high power amps have a relay that disconnects the speaker until balance is reached... but the smaller amps do noot have this feature.
May 02, 2011 | Hartke Bass Amplifier Half Stack with...
Amplifier head is working but no sound from speakers. Head tested with external speakers and is OK.
A simple test is to connect internal speakers across an AA battery (for about half a second) & listen for a click as battery is connected & another as battery is disconnected.
If this does not happen, check the internal jack plug connection & its connection to the speakers.
If OK, then you can test each speaker individually using the same battery across each in turn.
If this advice is helpful, I would appreciate a rating.
Apr 10, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
My amp has output but no sound from the speaker.
If you have tested with other speakers, you may have blown the ones that are not working. Test the speaker(s) on another source. I am not sure how you have tested your amp that it "has output"... indicators mean NOTHING on the amps as far as actual power going out.
Jan 29, 2011 | Hartke Ha2500 250watt Bass Amplifier Head
Amps in a seires
I'm not sure what this will do, but electrically you can hook these up. Using the line output from the swx, connect it to the line level input. I think that that would be the active input. When you connect a guitar(without a battery powered pickup) to the hartke, it goes to the passive input right? If so, then connect the line out of the swx to the active input. Reverse if the behavior is opposite of what I described.
Realise that with these two connected to each other, you will be using both pre-amp sections and the amp section of the hartke.
Dan
Mar 01, 2010 | Music
Hartke VX3500 Bass Guitar Combo Amplifier Logo
307 people viewed this question
Top Hartke Music Experts
dave nyman
Level 1 Expert
Tom Chichester
Robert Graf
Are you a Hartke Music Expert? Answer questions, earn points and help others
