Question about Vtech DS6151 Cordless Phone
Change message on V tech DS6151 - Vtech DS6151 Cordless Phone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Follow the instructions beginning on page 23 of the manual.
Posted on Oct 25, 2012
When Message EC 40,tech said it was the fan & something else.I asked if compressor needed change & was told no need. Temperature in freezer up and down to 35 degrees.
Hallo
If a compressor gets change so should the driers gets change and also they need to clean the condensing coil.
Regard
May 19, 2016 | Sub-Zero Refrigerators
Tip
Simple setting in Outlook 2007 that may be able to shave time off your e-mail...
Outlook 2007: Automatically Close Original Message After You Reply or Foward” by Tech Recipes shows you a simple setting in Outlook 2007 that may be able to shave time off your e-mail workflow.
If you forward or reply to lots of messages, then this can be a real timesaver. By changing the configuration of Outlook, you can make it automatically close the original message after you have forwarded or replied to it.
Basically you head into Tools → Options → E-mail Options and check off “Close original message on reply or forward”. Hit the link to see Tech Recipes’ guided tour with plenty of screenshots.
on Dec 02, 2008 | Microsoft Office Outlook 2003 for PC
Deregister cs-6629 handset
If your handset will not deregister, before registering it on a base. Here are the steps;
Menu/Select *7890#
It will display "Test Base" arrow up to "Test Handset"
Press Menu/Select It will display "SW Version"
Arrow up to "next page"
Menu/Select to display "Regstr Clear"
Menu/Select to display "Reg Clear?"
Menu/Select you should hear a beep.
Unplug battery and wait 10 seconds. Lug in battery and place phone in base to register it.
No other handset can be in use when you register new handsets.
Worked great for my 3 handsets that were registered to a base that went bad.
Nov 26, 2012 | Vtech DS6151 Cordless Phone
I need help in changing my voice mail message on a Motorola VGA 4XZOOM phone.....please help
Hey Tony,
Changing the voicemail message is as easy as calling your voicemail, selecting SETTINGS from the main menu and re-recording the message.
The type of phone (equipment) does not matter .
If you have problems and are unable to do it this way , then dial 611 from your phone and talk to a service tech regarding voicemail (option 5 I think...?).
Sep 30, 2011 | Cell Phones
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
How to I change the receipt message with a Sharp er-a440?
Turn key to PGM2 mode 1. type 2614 2. press . (decimal point) 3. press X (next to decimal point - on USA model, labelled @/FOR) 4. now type the line number you want to change e.g 4 for fourth line 5. press X (next to decimal point) 6. now type the new message using the alphabet on the front edge of each button. If someone has removed the letters, you can find a layout in the operating manual under "USING CHARACTER KEYS ON THE KEYBOARD" 7. ST (subtotal) 8. TL (cash button)
If anyone needs / looking for a Sharp ER-A440 or ER-A450 manual,
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_and_ER-A450_programming_manual.html
440 Instruction manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_instruction_manual.html
440 service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_service_manual.html
Aug 05, 2010 | Casio Parts Cash Register PC Desktop
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Messages are blocked, touchscreen doesn't work in messages, can't open any message and can't change anymore of screen once I am in messages (got also 10 times the same message, message function seems...
phone may need a master reset and getting same messages 10 times is a network error...you may have to contact your carrier tech support department and tell them about multiple messages...they may have to create a ticket for engineers to fix
Mar 22, 2010 | Cell Phones
RCA 25414 message light... doesn't
I have 6 of these phones. No problem for a year or so, then one phone got the message light stuck on. Tried some online suggestions without success. Powering down etc. failed to fix it so I stuck a piece of tape over the led.
A couple of weeks ago line 2 failed (externally) and ATT sent a tech out who repaired it and also cleaned up the line. When the line came back, all 6 phones had the message light stuck on!
Talked with the tech here and with the ATT support and nothing worked. Eventually the tech here left as it was not a line fault - but he said he would leave the problem open.
That evening a young ATT guy called. He tried a number of different settings and changes - he was really determined! He called Kentucky and Minnesota and part of the advice was "give up and don't call the customer back"!
Finally he found a configuration option in the central office switch (exchange) for the line called CWMI (Call Waiting Message Indicator). Apparently this option was originally active but was changed when the local trunk was upgraded to fibre over the last year or so.
Once he enabled this option (we have call waiting and caller ID on call waiting on this line), the message lights on all the phones turned off and have worked normally since (10 days), including the one that was "broken" for over a year!
I really credit the tech with persistance on the issue.
Hope this helps someone else out there.
Regards, Hugh
Jul 03, 2008 | RCA 25414RE3 Corded Phone
Voice mail indicator light is always on
I recently changed my number and when I did, I received the same problem. It appears that AT&T didn't add the Message Indicator Light service to my new number. Once they did, the message light works!
Try calling your phone service provider and asking if they have a Message Indicator Light function.
Apr 28, 2008 | RCA 25414RE3 Corded Phone
Vtech DS6151  Cordless Phone Logo
29 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
