Question about Sewing Machines
Usha janome allure how to fix the shuttle
I had to dismantle the shuttle and shuttle ring because the needle broke and got stuck. but i cant fix it back inspite of following the instruction manual. the shuttle is always loose and the bobbin case does not fit correctly. please help
3 Suggested Answers
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
  • 1788 Answers
SOURCE: the needle jammed down in
I solved it myself this way. This is not hard, in fact you can go to www.singerco.com and download your manual for free, then go to page, 82, and enlarge( 200%) the diagram, you then can see your parts really easy. Just take a deep breath and relax, you can do this. Let me know if this helps. I know it is so frustrating when that little thing does not want to cooperate. Good luck. You can also call Singer customer service at 1-800-4singer
Posted on Oct 12, 2010
Usha janome magic stitch removal of right side cover
If it is computerized, take it for service.
If it is a mechanical machine (not computerized), it probably needs oil. Old oil turns to glue and seizes the moving parts.
Use either fresh good quality sewing machine oil or pick up some Tri-Flow Synthetic Lube. Open the top of the machine, the cover over the left side, and the bottom bobbin area. Gently wiggle the handwheel and apply 1-2 drops of oil every place metal rubs on metal--do NOT oil belts, synthetic parts, Cams. You can follow up with hot air from a handheld hairdryer into the internal mechanism.
Your mechanical machine needs regular oiling--on the hook/shuttle every 8 hours of use, all over (as described above) every 40 hours of use, or every 6 months if in storage.
Oct 16, 2016 | Janome Sewing Machines
My Usha janome allure machine is not giving stitches. And the thread curdles below.
bottom tension is not correct take bobbin out and rethread it HOLD both upper and lower threads tight . when first starting to sew
Feb 09, 2015 | Janome Sewing Machines
Usha flair model
If you check on your machine, there will be a switch or dial (depending on model) that also has a blue color. That is probably for stretch stitching. You will have to change the switch or dial to the stretch stitch setting and then you will get those stitches. No need to change the needle plate. You will only need to change to a ball point needle if you are stitching on knit. Otherwise a regular needle will be fine.
May 03, 2014 | Janome Sewing Machines
How to fit the bobbin holder called the shuttle into the machine correctly
Lean the machine at an angle so it will not fall out...Hook will only fit one way, then ring with "bull horns" that go to the top rear, then lugs hold it on then insert bobbin case
Mar 10, 2014 | Janome Sewing Machines
I have Usha allure,sometimes it gives skipped stitch,and sometimes it gives bunches at the bottom. If I use thin thread for interlock, it dosnt accept, what is the solution?
Sounds most likely to be either thread tension issue - check bobbin tension OR dull / bent needle - put a new needle in suitable for fabric being sewn. Use good quality thread.
Oct 13, 2013 | Sewing Machines
The needle and thread get stuck at the bobbin and the lo light come on my 8077
Turn the power off and replace the needle with a new one, making sure the install is as described in the manual for your machine - on most newer models, this is with the flat side of the needle shank facing the back of the machine.
Before turning the power back on, raise the needle to it's highest position. Remove the face plate, bobbin and bobbin case. Clean the area in and around the shuttle from lint and/or threads that may be tangled there.
May 15, 2010 | Janome 8080 Computerized Sewing Machine
Hi FixYa team, I need a Manual for USHA Janome Wonder
www.mouthshut.com/.../Sewing_Machines_reviews-925345.html
Jun 19, 2009 | Janome 6019QC Mechanical Sewing Machine
Janome memory craft wont go forward
soulnds like you need a bobbin case.
Apr 02, 2009 | Janome Sewing Machines
Sewing Machines Logo
105 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
