Please tell me if I can install this SSD drive in my Acer Aspire V3-771G laptop. What is the difference between SSD SATA II and III
  • 242 Answers
The major difference between the SSD SATA II and III is the speed of info transfer. SATA II is 3GB/s and SATA III is 6 GB/s. I'm pretty sure that your laptop already has a 120GB SSD SATA II drive installed. You can add a SATA III drive with no issues, but I don't think that your laptop can actually work at the SATA III speed. This should not be an issue.
Posted on Oct 25, 2012
  • 47 Answers
A sata 3 SSD on a sata 2 PC will slow down slightly to sata 2 speeds, and vice versa. But this is usually acceptable since any current model SSD is much much faster than a normal hard drive so even installing a slower model SSD will be a big improvement. Its analogous to a porsche 911 and a volkswagen beetle. The 911 is faster than the beetle but both are much faster than horses.
your laptop has a normal hard drive. Most SSD's except apple SSD's are the same size and have the same connectors so 99% of the time it will work. you can see pictures of the SSD and compare it with your current hard drive
Pyrhyc
  • 2028 Answers
SOURCE: acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
Posted on Aug 30, 2008
SOURCE: Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Posted on Oct 16, 2008
  • 30 Answers
SOURCE: Reset Acer Aspire One to factory settings--clean hard drive
You will have to order the erecovery cds from Acer to put it back to factory settings. They can about $40.00 to $50.00 dollars and they arrive about a week after you order them. Once you get them, you boot from cdrom and follow the instructions on the screen.
Go to Acer.com to order them.
Posted on Dec 28, 2008
  • 45 Answers
SOURCE: Install Xp on Acer Asprie 5735z
I'd reccomend backing up data and formatting your hard drive. Then install XP from disk and put data back on hard drive. You could use external hard drive or jumpdrive. It stands to reason that SATA works with XP, because the new computers I have seen have SATA and XP working conflict-free.
Posted on Feb 13, 2009
  • 788 Answers
SOURCE: What type of hard drive is in my ACER Aspire 5920
SATA, I am leaving you a webpage for more information on your laptop.
http://support.acer-euro.com/drivers/notebook/as_5920.html
Posted on Oct 20, 2009
Where can I get the Best & Fastest M.2 Solid State Drive SSD?
kingston sshd units are currently the best with the best reviews when compared to other brands
e-bay sell them so check the details for each unit before ordering
Jun 07, 2017 | Best Computers & Internet
What are the specification of PS4 HDD?
  1. There are some of the specifications that you can look for to get a Hard Disk Drive is as follows -
  • 2.5-inch form factor.
  • 9.5mm thick or less.
  • Interfaced with Serial ATA (SATA) only.
  • Hard drive's type doesn't matter.
  • Speed also doesn't matter.
You can also get the detailed knowledge on the specifications that you must follow and other details through one of the best site that I've been using since last year to get all the details on latest updates, and many more from PS4 hard drive.
Oct 14, 2016 | Sony PlayStation 4
SATA port 0 INTEL ssd locked
Please check the solution here:
1) Find or make an XP install with SATA set to IDE mode
2) Install .NET 2.0 & Intel SSD Toolbox
3) Shut down
4) Connect up your 'bricked' Intel SSD
5) Turn on system
6) Start Intel SSD Toolbox, and the SSD should now show up
7) Start another secure erase on it, and it should go through
8) Your Intel SSD is now unlocked again
http://forum.notebookreview.com/threads/how-to-resurrect-an-intel-ssd-locked-by-the-intel-ssd-toolbox.583269
You might also want to follow this Microsoft KB - You receive Stop 0x0000007B error after you move the Windows XP system...
And for some background info - https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
Hope that helps!
Peace
Apr 20, 2015 | Acer Aspire 5610-4648 Notebook
What replacement soiled state hard drive for WD1200BEVS-22LATO
Examine the interface specifications for the what the HD is connected to. Most 120 MD SSD's are backwards compatible with SATA-150. Usually the specification with say SATA-II (3MB transfer speed) or SATA-III (6MB transfer speed). A SATA-III SSD will work on a SATA-II connecction.
Jul 08, 2014 | Western Digital WD1200BEVS-22LATO Scorpio...
Can't install windows 8 on a Samsung MZ-7TE120BW SSD drive
When you are starting the new install, Windows asks for drivers, point to where the drivers are located.
Apr 21, 2014 | Samsung MZ-7TE120BW 120 GB 2.5" Solid...
How do i go about finding the fm station to get the audio?
Hello monron123028, go to this "Website."
You'll be able to "Download [PDF] Reference Guides, and Product Sheets.
That will give you the opportunity to gather more information at your leisure.
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: sata-ii-2-5-ssd.html">http://www.ocztechnology.com/ocz-onyx-series-sata-ii-2-5-ssd.html
Feb 17, 2011 | OCZ Technology Onyx Series 128 GB SATA II...
I want to replace my harddrive on my acer one
better to take it to the technicians if you are using a lap top. you don't want to mess around with laptops dude
Apr 05, 2010 | Acer Aspire One PC Notebook
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
441 people viewed this question
David Payne
David Payne
