Question about Bose SoundDock Portable Digital Music System for Apple iPod - Black
Bose sounddock remote control can't open the battery cover on the back
I need to replace the battery in the remote control. The backside has a 1" round section that has a vertical notch that is about 3/4" long, that looks like it would be easily opened by using a quarter and turning it. However, it doesn't turn (is seemingly glued shut).
  • Gail Baggs
    Gail Baggs May 13, 2014
    I can't get the cover off of my remote with a coin or anything. I'm afraid of "stripping" the groove. ing
SOURCE: Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Posted on Jul 22, 2008
  • 20 Answers
SOURCE: BOSE SOUNDOCK CONNECTRO BROKE
You can't - the repair needs to be done centrally as the company would be at risk if it sold electrical parts to people who aren't qualified to repair such items. Therefore you need to call Bose and have this repaired, however it's quite a common fault so shouldn't cost too much.
Posted on Dec 31, 2008
SOURCE: missing power cable for Bose Sounddock
i did the same thing.... i worked for ccity and when we were closing they were about to throw away the display soooo it found its way 2 my car... there was no power port... call bose and go through the automated bs and tell the customer service rep ur power cable died and u tested "ur friends power cable" and it worked fine... tell them u need both parts and if its like my item it should still b under warrenty and they will ship it for free. if not u can just order the parts.
Posted on Mar 10, 2009
cjackHD
  • 71 Answers
SOURCE: Bose sounddock remote and ipod menu functions
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan. If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
Posted on Jun 22, 2009
SOURCE: I've lost the power charger for my portable sounddock
If you call bose directly they can sell one to you for around $60
Posted on Jul 11, 2009
A verticle line in the picture "Top Down Dead
The symptom of your television is vertical problem.The problem is in vertical section of the board.Maybe theres a leak capacitor in vertical section.So try to replace the leak capacitor,the value is 100mf 35 v.You can identify the leak capacitor through visual checking if you have no knowledge in using tester to identify the leak capacitor.If you can see the capacitor have rounded shape at the top while the good capacitor is flated shape.
Aug 18, 2011 | Televison & Video
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Our fan will not work. remote battery is fresh but fan will not operate. i believe the 4 notch positions in the remote are correct. are there notches in the fan? which way should the notches be facing?
In addition to the battery in the remote control, there is another one, inside the fan's motor cowling. If you didn't change that one too, that was the original problem.
Now as far as the pin notches on the hand held are concerned ... If you can remember their original position, return them to that and replace the other battery. If you can't recall them, the remote receiver where the other battery is located, behind the fan's motor cowling, will also have the same number of pin notches. Look at that one and match the hand held remote to those.
Hope this helps you solve the problem.
May 16, 2011 | Hampton Bay Heating & Cooling
While going through the setup procedure the Set 3 was accidentally changed to Set 1. Any activation of the Control setting only makes the unit go to "Set 1" It appears to be locked up at that...
You can try resetting the remote itself (this is necessary whenever the batteries are replaced). Remove the batteries, as if to replace them, press any key on remote (to clear its buffer) then reinsert them. Next step, since your unit is 'Set 1' (or remote command mode 1 - DVD1/RC1) - you could (on the remote) press 1 and OK/ENTER together - hold them for 10 seconds, then release.
This should restore the remote to the unit. If it doesn't, a workshop service may be required to reset the unit internally, but at a cost. Try the remote battery reset first (even try using new batteries).
Apr 05, 2011 | Panasonic DMR-EH50S DVD Recorder
The remote on my chrysler Town and Country is not working. What kind of battery do I need and how do I open the remote control to replace the battery?
using a small flat blade pocket type screwdriver find the notch on the housing of the fob. Place the screwdriver in the notch and pry the two half apart. Then remove the battery and replace with one of the same. You can pick one up almost anywhere small batteries are sold.
Mar 25, 2010 | 2002 Chrysler Town & Country
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Can't open my optical wireless mouse to insert new batteries.
usually on the bottom of the mouse there is a little door with two notches or a single vertical notch which you need to carefully pry open and then insert your batteries as shown inside with + and - denotions.
Jul 29, 2009 | GE Wireless Optical Mouse
Where can I order (on line) a battery for the MX 3000 remote?
I had several batteries that I ordered and they have been all purchased. Since I make no money on the batteries and can only order in bulk I will only order them if I can round up over 50 customers who need MX-3000 batteries. If you need one, please go to www.totalcontrolremotes.com and get in touch with us by putting "MX-3000 battery needed" and we will add you to the list. Either way wil let you know by mid-March 09 if and when the order will be placed for additional batteries.
Feb 24, 2009 | Universal Remote Control MX-3000 LCD...
Lcd screen connection
You can try to reseat the LCD video connector on the motherboard. Follow these steps:
1) Remove the AC power and Battery.
2) Open the LCD display all the way flat.
3) Pry up on the notch on the right side of the keyboard bezel. This is the plastic cover that has the power button on it.
4) Unplug the LCD cable and reseat it into the connector. This is the round black cable that has a little ground screw.
If this doesn’t resolve your problem then you probably need a new LCD display panel. To replace the LCD panel you have to remove the LCD section from the laptop and disassemble the LCD plastics to get to the panel.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 6000 Notebook
Mkgregory
If the TV supports it, you can go into service mode by press ing the following on the remote control:
062596 i
This will take you into a service menu. It also changes channel as you press the keys, so change to a used channel to get a picture back.
I am not familiar with this model, but the principles should be the same.
Using the remote control to navigate the menu, you are looking for "allignments", and from there "Vertical Amplitude" or V/AMP or VA or similar.
BE CAREFUL when making adjustments, as you can permanently damage the TV if you adjust any critical settings.
When making changes, make a note of the original setting so you can put it back if its not the right option. Also only make changes 1 notch at a time. It will be obvious when you have the correct option, so if nothing is happening after 2 or 3 notches, then put it back. This will minimise risk to the TV.
When you have finished, look for a "Save settings" option, if not just press standby to get out of the service menu.
Jan 11, 2008 | Philips 27PT5445 27" TV
Bose SoundDock Portable Digital Music System for Apple iPod - Black Logo
843 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
