Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
The machine leaks water from the dispenser unit as it is trying to fill the machine with water. it is like it is plugged up, but if a small bit of water is left it will drain into the machine, I have turned the water pressure down, but it still overflows. HELP My 2 year old washer is dong the same thing. I had a technician come out and look at it and there is a piece of clothing between the inner and outer drums and it is also clogging the hose that lets water into the drum, so it pours out under the detergent dispenser.
The technician (not from Sears) says it will cost $450 to replace the drums and that I should scrap the washer.
He suggested that I might be able to remove the lip seal and if I am real lucky I might be able to pull the garment out, but he did not think it was likely.
He also said that this would be an easy fix with a top loader and tha I should buy a top loader!
  • kboyd20 Jan 03, 2009
    After looking around on FixYa I found others who had problems with socks or underwear getting stuck between the drums. So, I pulled back the seal and found where some of the clothing was sticking out, I then pulled it all out. It was a tank top. I put everything back together (the repair technician had partially disassembled the washer to diagnose the problem) and now it works perfectly!
  • Sol Mumey Feb 11, 2012
    I had the same symptoms. I was able to reach in a pull out a chewed up sock between the drum and the intake. I only had to take the front panels off (about 8 or 9 screws) to be able to reach up (needed to remove the main front panel to get the door away from the drums. Seems to be working now. Thanks!
  • 15,935 Answers
Unfortunately - some repairs are expensive (labor wise) and not financially sound to repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Soap dispenser overflows with water
Need to know how old machine is etc. dispenser could be clogged.
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Tank overflows. wont stop filling with water and spills onto floor.
unplug unit, if water still comes in than you have a bad water inlet switch.if not than you nead to check the line from the wwater level switch to the outer tube.if there are no leaks than you have a bad water level switch.
Dec 25, 2009 | Kenmore Washing Machines
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Our Washer is overflowing through the dispenser drawer
water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Sep 16, 2007 | Maytag Neptune MAH9700 Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
909 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
