Question about Dell Latitude D620 Notebook
How to fix error code 5300-119 dell latitude d620
Windows is not loading msg detected a fialure while writng and reading video memory.
SOURCE: Problems with Dell Inspiron 9400 Video Memory conflict -
This solution is totally incorrect. He is having the problem that many of us face with the GeForce Go 7900 GS and the Inspiron 9400. There is a known issue with eventual overheating and the video card going bad. This is specific to the single-pipeline chip, in which their is a new dual-pipeline style that fixes the cooling/overheating issue that eventually fries the video chip. Dell has not 100% took ownership of this. I am on my fourth fried video card (thank god for the 3-year warranty I got) in which they have previously replaced with the single-pipeline style. This time they are finally replacing the laptop with either a new Inspiron 9400 (better be dual-pipeline chip) or a NEW equivalent laptop.
Posted on Nov 07, 2008
MGCO420
  • 11 Answers
SOURCE: Dell Latitude D620 Full System Recovery?
It's easy to miss the point at which you hit Ctrl + F11. You need to hit Ctrl + F11 at the point you see the blue bar across the top of the screen, it will display www.dell.com. If this is still not working you can use the XP operating system CD to reinstall XP and the Dell drivers CD to reinstall the sound, video, network and other drivers. If Dell didn't send you the operating system CD, you should contact them.
Posted on Jan 14, 2009
  • 3940 Answers
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
Posted on May 17, 2009
  • 164 Answers
SOURCE: dell latiidue D620 beep codes
Manual:
http://support.dell.com/support/edocs/systems/latd620/en/index.htm
Hope this helps!
Posted on Mar 11, 2010
  • 6 Answers
SOURCE: need system unlock code for dell latitude
i can give master password
for any laptob dell or samsung or others
u can contact me on
ghost_unknown_0@hotmail.com
Posted on Jul 16, 2010
Wds error 193 ocured while loading JAVA VM??
Maybe there is a software kit missed for the Java VM in your Dell Latitude D620 ,so it can't install and load correctly.
Feb 10, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
Hi ive got a Dell Latitude D620 laptop i keep getting error code 1000-0146 dst log containd previous errors,is this hard drive dead? if so will it need an IDE or SATA hard drive dont know much about this...
mazaroonie82
Unfortunately the error that you getting means that there is a problem with the hard drive. So you will need to replace the drive in the system. Note the D620 uses a SATA drive.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 03, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
How do I read a memory stick in my Dell latitude
hi, just put the memory stick into your card/stick reader port on your laptop then wait a minute or two and if nothing appears on the screen just go into my computer and then you should see the stick listed under my computer, if not then you need to check if your laptop can read that sort of stick.
The kind of memory computers have problem with is like nokia memory cards but all memory sticks should work, if its a usb type stick then this will show up under my computer, it should load up on its own but if not look under my computer.
Let me know how you get on or if you need further assistance ok
Jan 20, 2010 | Dell Latitude D600 Notebook
I changed hard drives and now I can't load my programs back on
ok thanks for you prompt reply.
when you say laptop not reading HDD it allows you to see dell logo but after that there should be a msg an error msg saying no boot device been found..or just a black screen?
check BIOS if hdd is detected. if yes then it means windows is problem probably but we need to double check on this. run diags on the hdd alone use the dell diags disc. check if you get erorr code. running the diags is like this. keep tapping on F12 after seeing dell logo then insert disc when you see the options. select cd dvd rom drive then press enter then run diags custom test for hdd.
Dec 08, 2009 | Dell Latitude D505 Notebook
Dell latitude d620 wont turn on
Did you upgrade the RAM when you upgraded to Vista. The D620 does not have the resources to run vista as pre-configured and requires, at the least, a memory upgrade. 1gb or greater is recommended.
Please upgrade the ram, or try F8 during boot for Safe-Mode and see if your RAM is not the issue. To check the amount of RAM you have:
Press and Hold Windows Key + PauseBreak
If you still have 256mb or 512mb vista is likely to barely crawl.
Let us know what you find.
Apr 17, 2009 | Dell Latitude D620 Notebook
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
Apr 14, 2009 | Dell Inspiron 8500 Notebook
Your video card memory went bad, has to be replaced,
You have to have it serviced, you can take it to Best Buy to have it serviced if you don't want to pay the premium from the vender!
Dec 21, 2008 | Computers & Internet
Dell Latitude D620 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
