Question about Goodman Manufacturing Goodman GDH80603AX 60,000 BTU 80% Gas Furnace, 2 Stage, Multi-Speed,
I need to know if the supply air of the Goodman GDH80603A comes out near the front bottom half or the back bottom half of the unit?
I can not find manual showing where the supply air exits the unit, toward the front or back?
Goodman air condenser is humming but the fan does not come on
The most likely cause is the fan motor has failed. If it turns free then see if the capacitor is bad. Turn off the power remove the capacitor. Your local supply houses can test it for you.
Feb 15, 2013 | Goodman Manufacturing Goodman GSC130181...
Central air only blows a small amount of cool air out the vents. After running 12 hours it only cooled my small 1BR apartment 3 degrees. The filter has not been replaced since October 2009 but I can't seem...
I have a Goodman A/C unit APRF036-00B1. The out side unit seems to be sucking and bowing air, the coil is cool to the the touch and the blower seems to be turning. I've check what seems to be the obvious. A small amount of air is only coming out. Any suggestions?
Feb 21, 2011 | Goodman CKL36AR36 Air Conditioner
What type of capacitor comes with a 5 ton Goodman Air conditioning unit model number CK60-1C
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
Jun 21, 2010 | Goodman CKL60AR60 Air Conditioner
We have a Goodman gas pack (PGB 030075-1)and no heat. A/C works fine. We can get the blower to come on but nothing but cold air comes out. Do we have a pilot light on this unit that needs to be lit?
Amy,
There is no pilot light. It is electronic ignition.
If you have a gas supply and it is turned on you have electrical problems inside the unit.
Jan 04, 2010 | Goodman Heating & Cooling
Where is the reset button located on the Goodman CACF060C2A?
Check near the bottom of the outdoor unit, if there is a little red rubber button near where the copper tubing connects, push itin until you feel it click.
Oct 19, 2009 | Goodman CACF060C2A Air Conditioner
I have an old Goodman(1985) unit and the cover the cracked
tough to tell by the age they probably dont manufacturer parts for that model anymore try calling a goodman wholesaller otherwiseupgrading to a new 13seer unit will cut your operating cost in half
Jul 08, 2009 | Goodman CKL24AR24 Air Conditioner
I need to know the type or size(tons) air handler
3 and a half ton S3642C6AA
42 is the unit size then you divide that number by 12
May 05, 2009 | Heating & Cooling
Goodman gds80703 turns on and off intermittendly 3 light blinks
There will be a diagnostic code that will blink on the control board. Look thru the clear window at the control board after the unit does not light up. On the reverse of the front panel, you will find a wiring diagram and in that area there will be a diagnostic code table. Sounds like a bad gas valve.
Feb 15, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Brand new goodman 2 and half ton package unit runing all the time
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Jan 16, 2009 | Goodman CKL49AR49 Air Conditioner
GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Goodman Manufacturing Goodman GDH80603AX 60,000 BTU 80% Gas Furnace, 2 Stage, Multi-Speed, Logo
26 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
