Question about John Deere Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
John Deere GX 85 Code : 030424ZE Model : 28M707 Type : 1162-E1 Onto my John Deere Sabre 1338 Model 28M707 Type 0648-AL code 96022870
  • Anonymous Mar 14, 2014
    coo 14 90.08
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
As long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
  • 5 Answers
SOURCE: i got a 15.5hp john deere sabre and the drive belt
Try this site:
http://outdoorpowerinfo.com/repairs/deere_sabre_drive_belt.asp
Posted on Nov 17, 2009
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
How do i fix my engine smokes oil when i start it up
perhaps a complete motor overhaul . oil rings may be broke .
Oct 06, 2016 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Belt diagram john deere sabre 1338 GXABRF
the cheap john deeres are notorius for belt jump. Have to look at idler pulley while engaged in normal cutting height and see if it rides the upper edge of the idlers. I have had to bend up the idler arm so it runs a truer line into the pulley/idler so it doesnt creep over the edges.
Aug 30, 2014 | John Deere Garden
HOW LONG IS MOWER BELT ON SABRE 1995 RIDING MOWER 15HP 46 INCHCUT
Try John Deere,
http://www.deere.co.uk/wps/dcom/en_GB/regional_home.page
Jul 29, 2014 | John Deere Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
Where do i check the trans fluid on a 15.5 hp John Deere Sabre ? Can not see any drains or plugs. It is called a soft touch hydro. Thanks for your help!
Hi, the unit is a sealed type, you cannot change or check the fluid level. Hope this helps, regards Phil.
Jul 18, 2011 | John Deere Garden
Garden Logo
515 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
