Question about Kenmore Elite 45986 Front Load Washer
Code F29 is not in the booklet and I can't open the door, is there a way I can fix this because sears can't come out till Thursday, I have so much laundry to do
Code f29 in my book is Door Unlock Error Possible causes/procedure are as follows: 1 door lock mechanism is broken 2. door switch/lock unit failure. a. check door switch/lock unit for foreign objects. b. unplug washer or disconnect power. c. check wire harness connections to the door switch/lock unit and central control unit (ccu) d. check door switch contacts E the resistance of both door coils between pin 1 and 3 should be approx. 320 ohms... the door can be unlocked manually... to do this you 1. unplug washer. 2 remove the lower kick panel (i think 2 screws on bottom hold it on) 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a 1/4 of an inch or until a click is heard. 6 you should now be able to open the door.
Posted on Jan 04, 2009
W10158202A Washer shows F29 Error code.What is this and how it can fix?
Could be the machine is not level.
Unplug the machine
Remove the lower panel on the bottom front of the machine (3 number torx screws). There should be a technical information panel giving error codes etc.
You can manually open the door by reaching up and pulling on the door release tab located below the door switch
May 02, 2016 | Washing Machines
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
Code f29 will not start
The error code F29 indicates a problem with the door lock assembly. I recommend replacing the door lock assembly part number 8183270
searspartsdirect.com
Please see the instructions provided below.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Sears Home Services
SAFETY NOTICE: Be sure to disconnect power to the appliance before performing any repairs. If you are not comfortable with doing any voltage checks that might be recommended, please contact your local service provider for repairs. Be aware that there could be sharp edges inside the appliance that could cause cuts or other injuries to yourself or others. http://www.shopyourway.com/m/questions/1077653
Apr 28, 2015 | Kenmore Elite HE5t Washer
My Kenmore Elite is getting to hot. It flashes f-29
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated.
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
Check the above link for an detailed article above the same F29 error.
Courtesy:JSROCK - A senior expert of fixya.
Jun 10, 2010 | Kenmore Elite Oasis ST 7806 Dryer
Showing F29 ??
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated. Check the following:
  1. First, UNPLUG the washer in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that required in order to clear momentary glitches with the unit. If the error code reappears, proceed to step 2.
  2. Check the door switch/latch for foreign objects that may have become lodged in the mechanism and may be preventing it from operating.
  3. Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
COURTESY:JSROCK- A SENOR EXPERT OF FIXYA
May 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reprogram sears garage door remote opener
Click below to get to the manual you need. Just scroll through till you get to your model number.
http://www.managemyhome.com/mmh/owner_manuals/search?query=GARAGE+DOOR+OPENERS&find=
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
Intermittent problem w/Sears garage door opener transmitter
If the wall control is flashing, the lock has been engauged. Hold the lock button for 3 seconds to turn off. The light should be solid after doing this.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changing PIN
ok... got it " LiftMaster Professional Model # 2575". Is this correct...?
Kindly wait & I will post back here again...
Regards,
micro
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kenmore Elite 45986 Front Load Washer Logo
293 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
