Question about Panasonic KX-T7730 Corded Phone
Panasonic KX-t7020 - Sp-Phone light flashes constantly
Have a KX-T61610 Electronic Modular Switching System with 10 KX-t7020 hybrid system phones hooked to it. Has worked flawlessly for years. Recently tried to hook up two identical phones to a single internal line (so I would have two phones in same room sharing an internal system phone line). Phones work....suspect some features will not (seems to get confused on call waiting and when flashing to pick up second call).....but my major annoyance is the constant flashing of the SP-Phone light that never stops. ANY phone hooked to either of the RJ-11 jacks in that room will instantly do the same...indicates to me that the signal for the flashing is coming from the Modular Switching System box. It is not a function of how the phones are programmed, as you can move them to another location and everything is fine. I have the installation manual for the KX-T61610, but cannot find any reference to such performance as an indication of 'xxxxxx' so that I can begin troubleshooting. I have returned the system wiring to original configuration, yet any phone now connected to the RJ-11 jacks in that room will start flashing the Sp-Phone light.
  • pjinserra Jan 04, 2009
    Went back to original wiring configuration, reset the 61610, wired each phone separately back to the switching unit. Everything works fine....no damage to anything.
    Thanks,
  • Panasonic Master
  • 2,460 Answers
First of all, UNPLUG one of the PITS phones. A 61610 only allows you to use one system phone per jack. The damage is probably not permanent, but I'd look at how you wired those jacks together. The voltage on each pair of a jack can be measured; it's 24 volts DC for the center pair (red/green) and about 13 volts for the data pair (black/yellow) and nothing between the voice and data pairs.
I'm guessing that you may have crossed or shorted one of the wires.
The power of a station is in an odd/even arrangement. Go back to the cabinet and uplug the two extensions that feed your jacks and its mate and test from there. If they both work, you're good to go, if not....16 minus 10 equals 6 :-)
You might find that if the ports are damaged, you can still use them for single line sets. Look at it this way, you had about 20 years of flawless operation.
You can use call pickup to share two phones in a room, 40 is all pickup, 43 answers the page, and 4+the extension number IIRC picks up a specific ringing phone.
Carl
Posted on Jan 03, 2009
I need to delete voicemail feature from kx-t7020 and can't find instructions
Try Googling (Panasonic)(kx-t7020)(manual) without parens for instructions.
Jan 31, 2018 | Lands Phones
I have the KX-T7020. How do I reprogram the auto dial numbers?
Here's a guess. Is the 7020 the one with 16 buttons? If so, they are marked CO 1-12 and F1-4. You program them by putting the phone in PROG from the switch on the back of the phone, then press the button and 1. If it's a F button, dial 9 + number and STORE. If it's a CO button dial 29 + number and STORE.
If you're talking SYSTEM speed dial numbers, those are done from the display phone at jack 01 and putting the system in programming.
Carl
Mar 24, 2011 | Panasonic KX-T7020 Corded Phone
No dial tone at all on a PanasonicKX - T7020 phone.Other phones in the system work fine.
Did you swap it with another phone? The 7020 requires a 4-pin base cord and a port on the phone system. The sound comes from the inner pair of the cable, the data (lights on the set) from the second pair. You could have a bad cable, bad wiring, bad handset, handset cord, or bad base on the phone. Since your system has to have more than one phone (like a display phone somewhere), try swapping or moving the phone to a different jack.
Carl
Feb 24, 2011 | Panasonic KX-T7020 Corded Phone
Can you get a replacement battery for panasonic kx-t7020
No. There is no battery in a 7020. There is a battery in the KXT-xxx10 system and those are available most anywhere (3.6 volts Nicad IIRC). The newer systems don't have batteries.
Carl
Jan 28, 2011 | Panasonic KX-T7020 Corded Phone
I have a Panasonic KX-T7730 Advance Hybrid System.
This is most probably due to a faulty rj9 connector witch is the connectors between the handset/headset and phone. Try swopping this curly cord - most cords work on most phones.
If this answer was helpful please vote / rate
Jul 01, 2009 | Panasonic KX-T7730 Corded Phone
Incoming call rings one time and disconnects
Unplug all phones but one in jack 11 at the cabinet and have someone call in. If it doesn't work, you probably have a bad cabinet. If not, I'm guessing one of your extensions is faulty.
Carl
Apr 06, 2009 | Panasonic KX-TA308 Phone
I have a Panasonic KX-T61610 phone switching system. Some of my phone extentions are not working and some are. I have unpluged the unit and also pushed the reset and that didn't help. The extentions that...
Also, are there certain CO lines that can only work with this KX-T61610 system? Typical FXS? or any odd analog settings on CO lines or within the Key controller for the KX-T61610?
May 27, 2008 | Panasonic Lands Phones
Advanced hybrid system panasonic kx-t7730
how do i change my voice message on my answering machine??
Oct 29, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
1,321 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
