Question about Great Plains Industries Gpi& Fuel Pump
How do I change a fuel pump on my 1983 dodge truck?
  • 14,363 Answers
Fuel pump 1983 280zx
Hi Angela,could be a clogged fuel filter or a bad fuel pump,Here's a link showing you how to replace the fuel filter. Repair Guides Routine Maintenance Fuel Filter AutoZone com Here's another link to a new fuel filter. Duralast Fuel Filter FF651DL ReadReviews onDuralast FF651DL Here's another link on how to replace the fuel pump,change the filter first. Repair Guides Gasoline Fuel Injection System Electric Fuel Pump AutoZone...
Oct 31, 2016 | 1983 Nissan 280ZX
Were is the fuel pump located on a 1983 dodge prospecter truck
if it is mechinic it should be on the passanger side of the truck at the fward part of the motor
Dec 30, 2010 | 1983 Dodge Pickup
Hi i have a 1983 dodge ram pickup one day it just died so ive been on a long journey of changing parts ive replaced the fuel pump fuel filter pcv and egr valve all the relays took out the fusable links new...
Check the firewall for a ballast resister. It's a little porcelain thing with either one blade connected wire or two on each side. Held to the firewall with one bolt in the center. Change that, and keep a spare on hand.
Apr 08, 2010 | 1983 Dodge Pickup
Fuel pump wont stay on wont start replace the
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
Nov 10, 2009 | 1983 Dodge Pickup
Fuel system problems
Try running some fuel back through the feed line from the pump to the tank. Chances are you will see fuel leaking out of it somewhere. The pump on the engine pulls fuel. Even a pinhole will draw in air.
You did check the sock filter in the tank right?
Apr 25, 2009 | 1983 Dodge Ramcharger
I have a 1975 dodge w200 with a 360 in it i changed the plugs and wires and the timing is perfect when u put gas in the carb it runs and then dies what did i do wrong i changed the wires one by one
I would suggest checking the needle in seet in the carb - it may be missing, or not in place, or wore out. Also make sure that the air/fuel misture is set correctly. You could also need to replace the fuel pump (or buy an electric fuel pump and install it in the engine compartment). Last, check the gasket between the intake manifold and the carborator for any fuel leaks, as this will cause it to start, then die.
Mar 31, 2009 | 1983 Dodge Pickup
1983 toyota pickup 4x4 22re engine
Clogged fuel line... maybe fuel filter clogged. Air compressor can clear line. Blow out the line coming in to the carb from the tank.
Aug 03, 2008 | 1983 Toyota Pickup
Great Plains Industries Gpi& Fuel Pump  Logo
50 people viewed this question
Top Great Plains Industries Garden Experts
Steve
RSole
Mai Lor
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
