Question about Panasonic NN-S244 1000 Watts Convection / Microwave Oven
Microwave won't start, intermittent problem
I have a Panasonic NN-4455C - it's an older microwave made in June 1995. Non-inverter. It's been packed away for most of those years though, and only has about 3 years worth of use. The problem is that the microwave won't start about half of the time. I enter the time, press Start, and the microwave seems to want to start but then makes a clicking noise and resets. The clock resets and goes to "88:88" just like when it's first plugged in. If I repeat this several times in a row, I can sometimes get it to work. Once it's working, it stays working until the time runs out. Any suggestions as to what the problem could be and how to fix it? Thanks, Rob
  • Panasonic Master
  • 9,098 Answers
This can be caused by a bad connection on the control panel, at the fuse holder, or the thermal cutout / thermostat on the microwave. I would suspect a bad connection on the control panel which we can repair for you with our $39.95 nationwide service. We have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: I don't have an online source for an exploded view, but I may have a paper coipy here. If you are interested, follow up directly and I can see.
Posted on May 13, 2007
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
Oct 02, 2016 | Panasonic Microwave Ovens
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ..., Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
HOW TO reset panasonic microwave
check your safety interlock door switch..
Jul 22, 2014 | Panasonic NN-H965 Microwave Oven
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
My Panasonic NN-T994 Microwave oven died today. Would run for a few seconds with a clicking sound and an electrical smell. I removed the cover, restarted and found arcing from the area of what I think is...
From your description it does indicate a magnetron problem, you would be further ahead replacing the microwave oven when you consider the expense of the repair involved.
Feb 23, 2011 | Panasonic NN-T994SF Microwave Oven
Panasonic Inverter Microwave - plate stopped turning
panasnic nn st557w does not respond when i press start button
Oct 13, 2010 | Panasonic NN-H275 Microwave Oven
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Panasonic NN-S244 1000 Watts Convection / Microwave Oven Logo
146 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
